StopTech Brake Kit
Old Aug 22, 2006 | 05:05 PM
JustNO's Avatar
StopTech Brake Kit
I did a search, but couldn't find any info. Can I use StopTech Brake kit on my 97 Z28 ??? Its written "only for 98 -02 F-Body".
Old Aug 23, 2006 | 01:07 AM
lincmarkv's Avatar
Re: StopTech Brake Kit
It's designed to mount to the LS1 uprights. Either get LS1 uprights or do the mods that people do to make the LS1 brakes fit on the LT1 uprights.
More than likely you'd need new wheels as well.
Old Aug 23, 2006 | 03:23 AM
JustNO's Avatar
I have 18" wheels. I don't know what should I do to make fit. Is it hard?
Old Aug 23, 2006 | 09:06 AM
Fierotom's Avatar
I think the LS1 brake has only different calipers, brackets and rotors....
What do you find in a StopTech kit? only calipers and rotors?
Than you need LS1 brackets.....
can you post a link to this brake kit?
Old Aug 23, 2006 | 09:52 AM
JustNO's Avatar
http://www.stoptech.com/products/BBK/summary.shtml (Click on BUY and chose the Vehicle type)
Need anything else to get fit it my 97 Z28?
FRONT KIT: 332 x 32 mm Rotor/ 4 Piston Caliper
Two Wheel Front Big Brake Kit Includes:
- 2 Piece Floating Directional 332x32mm AeroRotors
- 4 Piston ST-40 Calipers
- Stainless Steel Brake Lines (Front Only)
- Caliper Mounting Brackets
- Street Performance Pads (Front Only)
Old Aug 24, 2006 | 01:59 AM
lincmarkv's Avatar
I already told you, you'll need the LS1 uprights, or grind off the nubs from the LT1 ones as people do when they fit the LS1 brakes. The kit comes with calipers, rotors, brackets, and brake lines - but they are designed for the LS1 brake system.
In regards to whether your wheels will fit - there's a template somewhere on StopTech's site. Print it out, paste it to some cardboard, and try to fit it within your wheels - 18" isn't as important as caliper clearance going outwards. Stock 17x9" SS wheels do not fit over the StopTech brakes, for instance, without a spacer - the 17" is large enough, but the offset is not right.
D
who has StopTech brakes on his car...
HarleyZ28
Oct 5, 2015 06:23 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
rockync7
Jan 1, 2015 05:10 AM
