Battery goes dead in two days...
Old Aug 20, 2006 | 07:34 PM
wrd1972's Avatar
My battery goes dead in two days, I have ruled out aftermarket stereo.
When you disconnect then reconnect the battery wires you get a great deal of sparking indicating current draw. Has anyone seen this before.
What can cause this to happen?
Old Aug 20, 2006 | 07:41 PM
lastZ's Avatar
Re: Battery goes dead in two days...
time for a new battery......or check your altenator
Old Aug 20, 2006 | 07:47 PM
Greed4Speed's Avatar
Mine did that. Had some dead cells.
Old Aug 21, 2006 | 08:11 AM
wrd1972's Avatar
New battery was installed less than a month ago.
Old Aug 21, 2006 | 08:25 AM
shoebox's Avatar
Check that your system is charging and that you have no parasitic drain when the engine is off.
Old Aug 21, 2006 | 09:29 AM
anaik's Avatar
Disconnect wires negative first positive second. Reconnect positve first negative second for minimal sparks. If you do the opposite you'll get sparks whether there is abnormal current draw or not.
Old Aug 21, 2006 | 02:27 PM
ze doktor's Avatar
it's quite possible one of your relays is bad and eating juice while the car is off. i had an issue with my fan relays and it would typically take 3 to 4 days to make the car unstartable.
Old Aug 24, 2006 | 01:25 PM
wrd1972's Avatar
I hooked up an amperage meter an found that I had 1 amp of current draw, sounded like a light bulb.
I found that I had my alarm trigger wire hooked up wrong on the trunk switch and light stayed on all the time. It was being fed voltage from the plunger switch under the hood.
The problem is I have to have the same phase switches (normally closed) which the trunk switch is not.
After I get a new switch for the trunk all will be well.
Just one of them little electrical glitches.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
