Something funny I just thought of...
Old Aug 2, 2006 | 11:58 AM
91_z28_4me's Avatar
Since the 5th gen Camaro won't be out for at least a year does that mean it won't have Gen IV small blocks? Will the 5th gen Camaro have a 5th gen small block? I thought it was amusing.
Carry on.
Old Aug 2, 2006 | 12:02 PM
graham's Avatar
Re: Something funny I just thought of...
lol....
Which motor was the first 4th generation SBC?
Old Aug 2, 2006 | 12:08 PM
RussStang's Avatar
I wonder just how often GM will deem it necessary to label engines as a "new" generation. We will be up to Gen XII pretty soon if they keep changing them that fast. Methinks that perhaps the LS2 should not have gotten a new Gen IV label, considering how similiar it is with an LS1.
Old Aug 3, 2006 | 04:07 AM
godofdragons's Avatar
it is the same block right? and they named it as an ls, so I think it should be considered the same generation.
Old Aug 3, 2006 | 07:56 AM
91_z28_4me's Avatar
Block is different. It has provisions for AFM and VVT which weren't fully tested and utilized on C6 LS2. The testing wasn't completed on the VVT and the AFM was decided against because it was a performance engine.
Old Aug 3, 2006 | 11:51 AM
OctaneZ28's Avatar
Disciple
IIRC, LS2 was the first GenIV.
LS1 was the first GenIII, appearing in fall 1996.
I kinda agree that the LS2/LS7/LS4 etc should still be called GenIII.
Although they are different, they're not THAT different.
Old Aug 3, 2006 | 11:57 AM
95 Z/28 LT1's Avatar
Super Moderator
I wonder what the odds of eventually seeing VVT swaps on LS2s will be?
Old Aug 3, 2006 | 12:40 PM
91_z28_4me's Avatar
The blocks are different and the LS7 heads are quite a bit different. The plumbing is all there for VVT and DOD so why would that make it a Gen III when they didn't have any of that extra stuff?
Old Aug 3, 2006 | 01:25 PM
RussStang's Avatar
Does that mean a VVT LS2 should be a Gen V? The LS2 is still largely the same as an LS1 block, as almost everything in an LS2 block works with an LS1. The LS7 heads are a good deal different. Should the LS7 have been Gen V, and the LS2 be Gen IV?
There were plenty of differences in the past SBC blocks for 40 years, and yet they all get the same label as Gen I. GM is going to be going through a lot of generations of engines in relatively little time if they keep labeling them as they are.
Old Aug 3, 2006 | 01:31 PM
91_z28_4me's Avatar
Are all Gen I blocks pretty much the same, same oiling system, same cooling system, same basic block, same basic features (or lack there of)? Are all Gen IIs pretty much LT1s, maybe a different intake but pretty much the same? Don't all Gen IIIs have the same oiling and cooling systems and there are 3 different intake manifolds, all with one of 2 different heads, though different valve sizes were available? Why do you think that the LS2 is a Gen III when it has a completely different oiling system and block? Sure the crankshaft is pretty much the same and the heads are similar to the nicest Gen III heads but the AFM provisions and changes to allow VVT make it a Gen IV engine! It shares more with the Gen IV AFM, VVT 5.3 than the LS1. Do you get it now???
Old Aug 3, 2006 | 02:29 PM
DrewSG's Avatar
The LS1 should've been the gen 2
Old Aug 4, 2006 | 12:07 AM
RussStang's Avatar
How are the heads similiar to the nicest Gen III heads? They are LS6 heads completely in design, minus the sodium filled exhaust valves. I think you are reaching. The LS6 block is different from an LS1 block; should they be a different generation? Ditto for the oiling system. How can you possibly justify saying something like the LS2 has a COMPLETELY different oiling system and block? That is ridiculous. Everything from a Gen IV motor will bolt to a Gen III, even the LS7 heads if the LS7 intake is used and the motor is bored out. I still stand by what I said; GM is getting overzealous in the way they keep changing the motor nomenclature.
Old Aug 4, 2006 | 12:08 AM
RussStang's Avatar
There should really only be 2 generations in my opinion.
Old Aug 4, 2006 | 12:29 AM
guionM's Avatar
Carry on.
Pretty amusing.
Well.... what gen is the new 6.2 V8?
Old Aug 4, 2006 | 12:46 AM
RussStang's Avatar
I guess that waits to be seen.
techstar
Aug 11, 2015 11:21 PM
KYWes
Aug 10, 2015 07:03 PM
colts0455
13
Aug 7, 2015 09:15 PM
techstar
Aug 6, 2015 11:20 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
