Where the hell can I put my amps???
Old Aug 1, 2006 | 06:56 PM
LPE_wannabe's Avatar
Exclamation Where the hell can I put my amps???
I have a 400 watt amp and a 75 watt amp and i can't figure out some where to put them besides the back deck in plain sight...i thought about building a cover and carpeting it but then there's the overheating problem...and there's certainly no where that i've found to hide them anywhere...any help would be great!!! thanks!!!
Old Aug 1, 2006 | 07:26 PM
romoranger's Avatar
Re: Where the hell can I put my amps???
in the trunk area i bolted mine to the beam at the back of the car.
Old Aug 1, 2006 | 11:06 PM
what beam??? do you have t-tops?
Old Aug 1, 2006 | 11:22 PM
eagleknight97's Avatar
http://www.subthump.com/acamarorack2.htm
Old Aug 6, 2006 | 01:07 PM
BandDirector Blk98ZM6's Avatar
If your amps are small enough, there's room in the spare tire well AND you can still keep the spare. Check out the link in my sig for pics as well as directions.
Old Aug 6, 2006 | 11:03 PM
Meatyshells's Avatar
lol band your spare tire in that pic has no wheel on it and theres no jack, so what the point of having a tire there?
i relooked at that pic so i guess the amp is mounted on the wheel?
any way nice job
Old Aug 6, 2006 | 11:17 PM
DUH!!! read the instructions page lol J/K!!! yeah i don't think my 400 watt component amp is going to fit inside my wheel and i know it won't fit behind it...so basically the amp is just sandwiched between the antena and the quarter???
Old Aug 7, 2006 | 12:14 AM
valter's Avatar
You can do a fan-cooled enclosure, rear wall is nice too, window tint helps... Under the seat is very hardcore, but works for a lot of people...
Old Aug 7, 2006 | 11:19 AM
yeah if i did the enclosure on the rear deck i would put some computer fans or something in there...i might be going with the back wall but i'd rather them be hidden somewhere...thanks
Old Aug 8, 2006 | 06:38 PM
PentaVolvo's Avatar
I have ttops and have 2 amps mounted on the rear wall
Old Aug 8, 2006 | 10:26 PM
does anybody have the mounting instructions to that subthump thing cause i have most of a piece of MDF left over from building my box so instead of buying a $70 piece i'll build a $5 one...i just haven't figured out the perfect way to mount it???
Old Aug 9, 2006 | 01:49 AM
PentaVolvo's Avatar
http://www.sounddomain.com/ride/133032/5
Old Aug 13, 2006 | 02:04 PM
any way nice job
The spare tire IS on the spare tire rim and the jack is moved behind the tire as well...if I ever have a flate I've got a spare and jack. All I have to do is cut the 2 wire ties that hold the amp board to the spare and everything will slide right out.
Old Aug 13, 2006 | 02:08 PM
I knew the 400 watt amp didn't have a chance, but I was thinking the 75 watt might have been able to fit...of course since you didn't provide dimensions or what amps you have, I had no way of knowing for sure.
Old Aug 13, 2006 | 10:58 PM
DrMilhouse's Avatar
I had four amps mounted on the back wall, I have t-tops.
NewsBot
Mar 19, 2015 12:20 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Jan 8, 2015 11:29 PM
Rino1313
Jul 19, 2002 04:31 PM
Rino1313
Jul 18, 2002 05:16 PM
