Go Back   CamaroZ28.Com Message Board > 1967-2002 Powertrain Discussion > LT1 Based Engine Tech
Reply Post New Thread
Thread Tools Display Modes
Old 09-07-2006, 05:37 PM   #31
NightTrain66
Re: Le3/Le2 H/C track times, Do I have a problem??
gotcha, it seems like the PCM should be close as long as the 02's, maf, TPS, etc are in good working order. I am not sure why it was rich on a tune that is designed for 30 lbers and you had 24 lbers installed. Hmmm.
Lloyd
__________________
Lloyd Elliott
972-617-5671
Elliottsportworks.com
NightTrain66 is offline   Reply With Quote
Old 09-07-2006, 05:45 PM   #32
Tricked-Out-Toy
Tricked-Out-Toy's Avatar
Send a message via AIM to Tricked-Out-Toy
Ok I feel real stupid, I just talked to Ion and he pulled my old order slip and I had him tune for a 58mm TB but for some reason I picked stock injectors!!?? damn do I feel stupid. so Im sending it back to him tomorrow and having him fix the injectors ill keep you posted.
__________________
91 White Z28
LT1,LE3 Heads LE2.2 Cam M6
http://www.cardomain.com/ride/2108104/1
Tricked-Out-Toy is offline   Reply With Quote
Old 09-07-2006, 06:34 PM   #33
NightTrain66
that makes alot more sense now as to how it could be rich with stock inj. also.
I am sure he'll get it lined out.
Lloyd
__________________
Lloyd Elliott
972-617-5671
Old 09-07-2006, 07:06 PM   #34
89385formula
Quote:
Originally Posted by Tricked-Out-Toy
No never had it on a dyno, I just got it back together 3-4 months ago. I know everyone says go bigger injectors but this thing puls like crazy to 6500. if the injectors were going static wouldnt I notice a "bog" or some sort of "buck"??
I entered the info into that calculator, is the altimeter setting the barimetic pressure divided by 1.01? if so I used 28.96
Desity Alitude --- 4229ft
Absolute Press -- 28.33in
Relitive Density is 88.2%
now whos gonna tell me what those number mean??
Also whats the best 60' anyone has gotten WITh street tires?
I know I am alittle late to respond but your times are low not only because of it being broken but also your DA is that high. Don't expect any new bests like that. Some members on this board run there best in sub zero DA or even low numbers like 500 or so. Your ET@4229 DA is 13.0@110, that corrected to sea level or 0 DA would be equivelant to a 12.3@116.
__________________
00' T/A M6
Bolt-ons. 353rwhp/357rwtq
Bolt-ons, BRE cam 421rwhp/389rwtq
89385formula is offline   Reply With Quote
Old 09-07-2006, 08:43 PM   #35
camzaro28
Send a message via AIM to camzaro28
just did it as well. lol
.9484 et
1.0549 mph
12.4@116.2
__________________
1997 z28
Bone stock, 14.7@95
bolt ons, 3200 fuddle 13.04@104.2
ported factory heads and crane 227 12.47@109.5
camzaro28 is offline   Reply With Quote
Old 09-07-2006, 10:19 PM   #36
z28trick
2.0 60' on street tires for me...mods in sig
__________________
1997 A4 - Artic White, Black Z06 wheels 295/35 R18 rear and 265/40 R17 front- Moroso cold air intake, TB bypass, !MAF screen, !Intake silencer, Flowmaster exhaust, TransGo Shift Kit, Dacco 2400-2800 stall, Hypertech Power Programmer III.
9.081@77.630 mph - 2.048 60' (1/8) no 1/4 times yet
1988 Ford Festiva M4 - Blue, Polished Aluminum wheels - Custom side exit glasspack exhaust, B&M T-Handle - 1.3 liters of fury!!!
http://www.cardomain.com/ride/2119789
z28trick is offline   Reply With Quote
Old 09-07-2006, 11:14 PM   #37
blackz97
Send a message via AIM to blackz97
yeah its a lot easier to do in a bolt on only A4 car ;-)
Steve
__________________
Black 97 Z28 M6, Haddad Motorsports built 11.1:1 355 Stock bottom end w/forged pistons, LE3 heads (283/197@.600), LE2.2 Cam, Cloyes Double Roller, Morel lifters, 1.6 Pro Mags, Delteq ignition, 38# injectors, LE Ported intake, Holly 58mm TB, CSR EWP, SLP CAI, Pacesetter LTs, Custom ORY, Mufflex 3.5" exhaust with spintec muffler, Madz28 OBDI conversion. Spec Stage 3, LS1 Drive Shaft, 4.10's out back. 404hp 381tq on Haddad Motorports Dynapack Dynamometer. www.haddadmotorsports.com
blackz97 is offline   Reply With Quote
Old 09-07-2006, 11:55 PM   #38
HardcoreRM125
Send a message via AIM to HardcoreRM125
Uhmm, you need to stop driving it. Your gonna just blow that ****ing thing up.
Your on the stock fuel pump. Stock 24 Lbs/Hrs injectors, and are tuned for 30 Lbs/Hrs ... That thing is probably leaning out so bad ... You dont want that 20 minute job to be the 20minute thing you didnt do that blew up your engine. And do that 5 hour job and switch fuel pupmps while your at it.
__________________
95' Z28 Vert M6, Pacesetter LT's, ORY, 3" Cutout, FM Cat-back, CAI, 1.6PM's, 918's, 10* Stuff, BRE Cam, PCMforless, 30# SVO, 255LPH Racetronix w/Hot Wire Kit, Mallory 685, 160*, LT4 KM, !AIR, !CAGS, Pro-5.0, Perma-Cool Oil Cooler, LCA, SFC, STB.
1999 Ram 2500 CTD 4X4 Bully Dog, CAI, 5" Straight Pipe w/ Stack.
HardcoreRM125 is offline   Reply With Quote
Old 10-14-2006, 06:02 PM   #39
Tricked-Out-Toy
Ok well Im bringing this back from the dead since I made the corrections everyone recommended and I gained a whole 2 tenths of a second!!!??? so heres a run down of whats going on. Everyone said the stock throttle body was hurting me so I switched out to a 58mm and ported my intake to match the new 58mm. everyone said I needed to upgrade my stock injectors so I did, installed 30#ers. I also sent the PCM back to ION for a retune to add the Injectors and the thottle body. Also the result a posted at the beginning of this thread were on a day when the weather was disgusting. today the weather was killer, the temp was down, humidity non existant. so heres my results from the best run I had.
R/T .414
60' 2.185
330 5.620
1/8 8.404
mph 89.23
1000 10.790
1/4 12.808
mph 111.79
Now I know the time isnt going to be great with a crappy 60' time but my MPH is really low! And someone on here said I needed to drive the car like I hated it well if power shifting it from 2-3 and 3-4 never lifting my foot from the floor isnt hating it I dont know what is. WHERE THE HELL IS MY MPH!!! im kinda frustrated, the only thing left is to get it on a dyno and tune it the right way but from ALL of the posts ive read/seen Ion's and PCM forless tunes are really really good and most ppl only gain 10-20hp is that really enough to get me into 115mph territory? we're talking 5-6+ mph. thanks for the help. I know I may have sounded like I didnt think the opinions about the throttle body and injectors were good or neccisary upgrades but I was expecting to see a bigger gain than what I ended up with. I mean if I ran the setup I ran when I got the times at the begining of this thread I could have easily hit these new times just with the cooler denser air. Thoughts?
__________________
91 White Z28
Old 10-14-2006, 06:26 PM   #40
96flame
Get it dyno tuned and go from there. I gainned 50rwhp 20rwtq over the mailorder tune. Also need a lot of work in the 60' department. You'll be happy once all the bugs are worked out trust me.
96flame is offline   Reply With Quote
Old 10-14-2006, 06:46 PM   #41
TransAm396
Send a message via AIM to TransAm396 Send a message via Yahoo to TransAm396
Damn. I went 13.4@106mph in a 93 with just a catback,3.73's CAI and an MSD....something def. aint right.
__________________
96 Blk Ws6 6spd-30kmiles-Ls1 WS6 FrontEnd conv.
PTK/T70 coming soon....
TransAm396 is offline   Reply With Quote
Old 10-14-2006, 06:55 PM   #42
FeelTheSpeed
what about the driver? How much experience do you have? I know a lot of people keep bettering their times the more experience they have.
FeelTheSpeed is offline   Reply With Quote
Old 10-14-2006, 07:04 PM   #43
Tricked-Out-Toy
Ive driven this car and stick cars all my life (I'm 25) like I said I litterally reved the hell out of it power shifting right before the rev limiter. I dont think it is the driver since my times are all very very consistent. I need to find someone that can tune it thats close to Nashville TN, anyone know of a place? one of the guys at the track was running a 96 LT1 with ported heads and an 847 and he was running pretty much the exact same times as me. he had his tuned at Dynolab in GA, that 5 hours from Nashville so I guess if I have to go there I will but there has to be someone that is closer!?
Heres the vid from my fastest run, sorry about the quality the camera was set on the "close up" setting.
http://videos.streetfire.net/video/e...5a0153ed6b.htm
__________________
91 White Z28
Old 10-14-2006, 08:40 PM   #44
playa7970
you need to deff get that thing dyno tuned its deff worth the money... like mentioned above a mail order tune will just get your by but if you really want to wake it up get it dynod
__________________
1994 Z28 383 Golen Comp Lt1 (Forged)
playa7970 is offline   Reply With Quote
Old 10-14-2006, 08:45 PM   #45
Tricked-Out-Toy
Well thats my last option, now PLEASE PLEASE does anyone know places near in Nashville TN or even up in KY. Id like to find a place thats within 3 hours of Nashville
__________________
91 White Z28
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Garage vBulletin Plugins by Drive Thru Online, Inc.
Copyright © 1996-2010 CamaroZ28.Com. All rights reserved.
Forums Directory
