Old 07-27-2006, 11:43 PM   #1
AlmosN8kd
Send a message via AIM to AlmosN8kd Send a message via MSN to AlmosN8kd Send a message via Yahoo to AlmosN8kd
Most practical set of headers (LT1)?
Ok, I know this is kind of a dumb question (I did search for a bit, I just didn't find what I was looking for) but I would like to know which set of headers would be the most practical. Basically, the practicality aspect I am curious about is which set of headers for the LT1 would make swapping plugs easier (while giving a small performance increase) because the stock exhaust manifolds are a huge PITA to work around. So far, the one that has seemed the most appealing for what I am looking for out of a set based on what it looks like is this set:
http://store.summitracing.com/partde...5&autoview=sku
I'll admit, I don't have a whole lot of experience with long tube headers so I am not sure if the set I am looking at is worth the price (or if it can be found cheaper elsewhere) and if they bolt up to the rest of the ehxaust with no modificiation required. Also, I don't know if Dyantech quality is worth a damn; here are others I have looked at on the same site:
http://store.summitracing.com/egnsea...7C0&rsview=sku
From looking at what is available, it would seem that long tube headers will do what I want where as the short ones will not. Also, I'm not sure what diameter inlet piping the headers would need to be to match the stock exhaust manifolds and what would be an upgrade. Anyhow, if someone with a bit more experience could take a few minutes to make some recommendations to me, I'd really appreciate the time. Thanks in advance.
AlmosN8kd is offline   Reply With Quote
Old 07-28-2006, 12:16 AM   #2
bringBackCamaro
Re: Most practical set of headers (LT1)?
2 words:
Coated Pacesetters
__________________
1997 Camaro 5.7L LT1 M6 Ttops + Double roller, !CAGS !AIR !EGR, !CATS, Pacesetter LT, Offroad Y, 160 Hyperstat, TB AirFoil, 52mm TB, Hooker 3" CatBack, B&M Ripper Shifter, LT4 KM, Moroso Cold Air, PowerSlot Rotors and Hawk Pads, Meziere WP, PCM4Less tune, Racetronix pump
bringBackCamaro is offline   Reply With Quote
Old 07-28-2006, 12:32 AM   #3
Misfits
slp - if u got the cash
edelbrock - nice gains
Misfits is offline   Reply With Quote
Old 07-28-2006, 12:40 AM   #4
CamaroRacing12
Send a message via AIM to CamaroRacing12
wat has the best gains?
__________________
95 black z28 A4 3.23's..Moroso CAI, Trick Flow Elbow, Pacesetter Longtubes with 3" True Duals X-Pipe dumped, CPT Pro Race 4l60e, SS3600, LS1 Driveshaft, Prostars wrapped in et street radials...also weight reductions. NED- 12.49 @ 107.32mph 1.69 60ft soon to come: !front bumber support, !AC, !EGR, !AIR, lightweight battery, VFN reg sunoco pin on hood, Chromoly adjustable LCA's w/relobrackets, SFC's
CamaroRacing12 is offline   Reply With Quote
Old 07-28-2006, 04:23 AM   #5
RedLT4Mike
Premium Member
RedLT4Mike's Avatar
Send a message via AIM to RedLT4Mike
slp has a massive price reduction on their 93 mids right now
stainless steel!
__________________
1995 Pontiac Trans Am
383ci. || LE2-LT4 Heads-Intake, Joe O. 234,246 .573 .565, 109 lsa
CSR WaterPump || 17x11 ZR1's w/ MT ET Street Radials
Moser 9in. 4.10's-Spool || 6-Speed w/RamPGHD || B&M Ripper Shifter || NX Wet
RedLT4Mike is online now   Reply With Quote
Old 07-28-2006, 05:56 AM   #6
AlmosN8kd
I'm not looking for what has the most gain performance wise, I'm looking for the set that would be the most practical for working on the car. The Pacesetters seem to wrap over the top much like the stock manifolds do, which appears to still be difficult for doing work down on the side of the engine. The Dynatech one that I looked at seems to be the only set that has no over lap but I have no idea if they are even a decent quality product. Also, I am not sure which of the available sets will bolt to the remaining stock exhaust.
Old 07-28-2006, 06:55 AM   #7
PoorMan
Mac mids. Good plug access. Bolts to stock cat.
http://www.macperformance.com/store/...Product_ID=457
__________________
'94 Z28 Blk Vert. A4->M6, AS&M CAI, AS&M 54mm TB, CC503 XE 224/230 (.553/.561 lift w/ 1.65 RR's), LE Stage 3 Heads, 30lb SVO injectors, JetHot LTs, X-pipe Duals, Pro 5.0 Shifter/Short stick, Mccleod 7500rpm single disc w/ Ram Alum flywheel, 3.42 gears, LT4 Knock Module Install pictures _ Dyno Run
PoorMan is offline   Reply With Quote
Old 07-28-2006, 08:30 AM   #8
gt_biker13
SLPs are on a great deal right now and theyre stainless steel. You would have to get rid of your emmissions and you would need to get a 3" cat or 3" pipe to mate it to the rest of your exhaust. Mac headers have a good reputation for plug access and you can keep your emmissions stuff and it should bolt in with minimal modification. The Macs are just made of regular steel though, that shiny coating will turn to rust in a couple years.
The picture of those headers are for an LS1 camaro, they wont fit yours.
__________________
1995 Z28 Convertible. Black
Picture-Video-Cardomain
A4, stock 3.23s, SLP headers, Magnaflow exhaust, Lingenfelter CAI, 98+ Front brakes, 17x9.5/11 polished ZR1s with GSD3s, !EGR, !AIR. JW 3200 stall.
gt_biker13 is offline   Reply With Quote
Old 07-28-2006, 08:52 AM   #9
Javier97Z28
Javier97Z28's Avatar
I see you're asking about "direct bolt-in"....
You're not going to bolt longtubes up to stock exhaust by just replacing the manifolds. You'll need a y-pipe to go along with it plus welding a flange on the end to mate to the catback (better than welding the ypipe to the catback)
__________________
'97 Bright Green Metallic Z28 A4
Current best 11.14 @ 120.06 1.542 60' (Best MPH 11.18 @ 120.33)
355 LT1 - LE2 Heads - LE3 Cam - All the Bolt Ons - Moser 9" 4.11's - CPT Pro Race 4L60E - Yank PT4000 - 3" X-Pipe/Bullets
Javier97Z28 is offline   Reply With Quote
Old 07-28-2006, 08:57 AM   #10
wrd1972
Premium Member
wrd1972's Avatar
Practical implies:
easy to install
easy plug access
proven quality and performance
value
emmision friendly
The only header that is this is Mac headers, preferrably coated.
That is the most practical.
Yes LT's and a few other mids perform better, but they may cost more, plug access sux and they are harder to install.
__________________
1995 Z28 Convertible, 355ci M6 LT1 built by Kennedy Performance. DYNO 384 RWHP/361 RWTQ SAE thru the 9" Truetrac
Performance Mods 6" rod Mahle pistons, LE2 heads w/ Patriot xtremes, 224/230 LE1 billet cam, LE ported intake, Midwest 9" w/4.11's, BBK 58MM TB, LPP Long tube headers, Pro mag 1.6 RR's, Tuned by BLUECAT.Pic top down. Pic top up. Pics of my True Duals.
wrd1972 is offline   Reply With Quote
Old 07-28-2006, 09:04 AM   #11
Sweetred95ta
Sweetred95ta's Avatar
Send a message via AIM to Sweetred95ta
My Jet Hot Longtubes have excellent plug access. I can take my time gapping all of the plugs, using dielectric grease, and making sure everything is right, and still get them done in a 1/2 hr.
__________________
Benji - 1995 Trans Am - A4 (Now M6): Forged 355, H/C (Joe O Cam), 9" 4.22:1, TNT F2, ect. 403 rwhp/395 rwtq (w/ valve float)
Quote:
Originally Posted by micfly83 View Post
Up in my top list of fears next to sharks and getting my balls cut off, is a spun bearing, so I'm praying to god thats not it.
Sweetred95ta is offline   Reply With Quote
Old 07-28-2006, 09:21 AM   #12
Injuneer
Super Moderator
Do you have to meet any sort of emissions inspection, particularly "visual"? That will determine what headers you have to select from. There are not many 96 dual-cat emisions certified headers.
__________________
Fred
94 Formula A3+1: 381/TH400+OD/N2O 11.1 @ 128 on a 125-shot
Detailed Mod's List - - - - Step into my office.... - - - - Trailer Queen......
Injuneer is offline   Reply With Quote
Old 07-28-2006, 11:39 AM   #13
Hot94Z28
I have Hooker shorties that are coated and love them #6 plug is the only one I have any trouble with other than that I can change all of them from the top with little or no prob and it has all the emmision stuff on it
Hot94Z28 is offline   Reply With Quote
Old 07-28-2006, 12:07 PM   #14
stereomandan
Premium Member
stereomandan's Avatar
If you want headers, you should get a catback as well, otherwise you will not see near the gains because the stock muffler will choke the exhaust.
I also have a OBDII LT1 ('96-'97). I bought the '94-'95 style Mac mids coated directly from www.jet-hot.com I also changed my catback to a '94-'95 style Hooker Aerochamber catback. All you need to do is fab up a cat, or bullet muffler to connect the Y-pipe to the catback. I have a write-up on here somewhere with how I did it. You'll also need rear O2 sims, or have them programmed out, but that's the case with almost any header.
I gained 35 rwhp and 30 rwtq from the headers and catback. It was a huge gain, and worth every penny. Roughly $280 for the catback, $550 for the headers, and $90 for the cat.
Plug access is awesome, the sound is incredible, and they installed well.
Dan
__________________
Mods, Yeah, I have mods : Click Here for Car Webpage
Go Fast, Corner Fast, Stop Fast
1997 Z28 M6, Bolt-On Only
13.40@ 105.5, 2.15 60'
stereomandan is offline   Reply With Quote
Old 07-28-2006, 12:27 PM   #15
matLT1
I have hooker Lt's and the plugs are very easy to change except for the #6and 8. Ground clearance is fine as long as you don't have a lowered car (I've never scraped). Installation is a pain but its not like you will do it a billion times. Do it once and do it right.
__________________
1994 Z-28 Turbo conversion in process 2008 Impala LT - Black on Black with heated leather seats, remote start, MP3, moonroof
matLT1 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
