Help with vibration (already searched)
OK, so I already did a huge search and turned up nothing. My problem seems to be different than what everyone else is experiencing. It goes like this...
Vibration occurs above speeds of 80mph or so. It is felt though the car body, shifter, and clutch pedal. Its quite extreme. You can feel it in the clutch pedal when you just barely have your foot touching it, not depressing it at all. Now here's the kicker - vibration goes away when I push in (disengage) the clutch. Let the clutch out (still at 80+mph) and the vibration returns.
I'm really thinking its not my DS or U-joints or gears or tires, since disengaging the clutch doesn't make them spin any slower. The car has a Pro 5.0 shifter, SLP clutch package, 4.10 gears, stock steel DS, and poly trans mount. That's all the mods that should matter.
Any ideas?
Any ideas?
Re: Help with vibration (already searched)
i'm very interested to know what you find. my 95 firebird does the same thing at and above 80. i hope someone can shed some light.-- i know this does not help, but interesting we both have a strange vibration.
what if the ds is sending the vibration through the tranny and engine. hence when you push the clutch and disengage the tranny the vibration stops.
i would put money on the ds.
did you try it with the clutch out and rolling out of gear.
I notice that above 4000 RPM I get vibration. With the automatic, 1st gear is too quick to notice it, nobody but me would notice it in 2nd, but 3rd gear it vibrates like crazy once you get up there. Sounds like it's coming from the shifter.
I'm guessing it's the driveshaft, but my car came with the 1LE shaft.
So at 90-100 mph in 3rd at WOT I get vibration, but at 100 mph in O/D, no vibration.
well, i broke down and went to a drive shaft specialist this morning. everybody i talked to said he knows his stuff. real nice person. we took the car for some hwy riding and he told me i needed u-joints,trans mount and ds balanced. $85.00 labor +parts. he also told me my rearend would eventually need some attention. always something
he did tell me i had a strong motor. that seemed to impress him
autoxr166
Sep 25, 2015 04:21 PM
alliance12364
Sep 17, 2015 08:43 AM
Sep 11, 2015 09:44 AM
