Easy Monsoon Amplifier Bypass Wiring
Old Jul 25, 2006 | 06:13 AM
meissen's Avatar
Alright guys, I had the fun of upgrading speakers on Angie's 2002 Firebird with a Monsoon system today, and I wanted to share my findings with everyone else. Typically, what I've heard everyone say is that you either buy the specific speaker that works well with the amp, or you have to rewire from the headunit to the speaker so that you bypass the amp. The local major audio store that's in this area (Mickey Shore) told me to tap into the wires from the headunit so I could use the regular Infinity Reference series 6.5" speakers for the side/sail panel location. Using the wiring diagram found here, I tapped into those wires and then had to run new wire from the headunit to the side panels, which was very time consuming and required removing/unbolting interior panels to tuck wire behind them. When I wired the side speakers straight from the headunit to the speaker, bypassing the amp, the speaker sounded 100x better than the same speaker being powered by the amp (read the Monsoon amp for discussion on why). So, the decision was made to rewire the front door speakers too to effectively bypass the amp. The problem was running wire from the headunit to the speaker, having to go through that grommet that passes through to the inside of the door. Then it hit me,
THE EASY WAY TO BYPASS THE MONSOON AMPLIFIER FOR SPEAKER UPGRADES:
1. The Monsoon amp is located behind the spare wheel on the passenger side rear quarter panel. Remove the spair tire and equipment so you can easilly reach in and disconnect the large connector from the amp.
2. Once you have the connector unplugged, use the following wiring diagram for Camaro or Firebird and find out what wires come from the headunit and what wires go out to the speaker. Because I just did this for my girlfriend's 2002 Firebird, below I'll use an example of what wires to splice together. Basically, the idea is that you're literally taking the wire that was supposed to go from the headunit into the amp and connecting it straight to the wire that was supposed to go from the amp to the speaker -- effectively bypassing the amp, and bypassing any needs for running new wires! My job rewiring and running new wires to the side panel speakers took 7 hours, whereas it only took me 1 hour to rewire the front speakers using the amp bypass approach.
2002 Firebird with Monsoon Amp Wiring Summary:
I only had to bypass the amp for the doorpanel speakers and the side/sail panel speakers. Here is the wiring I used:
E1 - Dark Green - Right Front Input (Negative) CONNECTS TO F6 - Dark Green - Right Front Speaker (Negative)
F1 - Light Green - Right Front Input (Positive) CONNECTS TO F7 - Orange - Right Front Speaker (Positive)
E2 - Grey - Left Front Input (Negative) CONNECTS TO E16 - Light Blue - Left Front Speaker (Negative)
E3 - Tan - Left Front Input (Positive) CONNECTS TO E15 - Dark Blue - Left Front Speaker (Positive)
E4 - Dark Blue - Right Rear Input (Positive) CONNECTS TO F14 - White - Right Rear Speaker (Positive)
E5 - Light Blue - Right Rear Input (Negative) CONNECTS TO F13 - Grey - Right Rear Speaker (Negative)
E6 - Yellow - Left Rear Input (Negative) CONNECTS TO F16 - Purple - Left Rear Speaker (Negative)
E7 - Brown - Left Rear Input (Positive) CONNECTS TO F15 - Red - Left Rear Speaker (Positive)
Just use your wire cutters and cut these wire pairs one at a time, then solder them together. It's a VERY easy job and you will spend more time removing the tire and equipment to get to the monsoon amp than you will actually cutting and splicing the wires together.
Using this idea, you'll have the front door speakers and the side/sail panel speakers bypassing the amp, while the stock tweeters and the stock subwoofer in the rear quarter panels are still powered by the amp. In my case, I just disconnected the crappy sounding "subwoofers" in the rear quarter panels and left it to be just a 4 speaker system with 2 additional tweeters in the front doors.
I hope this helps make life easier for you guys!
Old Jul 26, 2006 | 02:35 AM
PentaVolvo's Avatar
Re: Easy Monsoon Amplifier Bypass Wiring
Deff a great way to do it, ive done a many that way. No offense but did it really take 6 plus hours to rewire the rears
Old Jul 26, 2006 | 06:19 AM
meissen's Avatar
It took me from 2:30pm till about 6-7pm to rewire from the headunit to the side panels, it was definitely a leisure pace and the definite hangup was those blasted kick panels and trying to get the screws through the carpet into the holes.
Old Jul 31, 2006 | 10:42 PM
NYC32798's Avatar
Anyone know if this will work on the bose system?
Old Aug 2, 2006 | 12:26 AM
PentaVolvo's Avatar
Yeah it works on bose systems as well. The takin your leisure time makes more sense now and I know what you mean about getting the screws through the carpet
Old Aug 2, 2006 | 12:51 AM
NYC32798's Avatar
Iwas looking at this earlier:
http://shbox.com/1/bose_wiring.jpg
It seems that all of the positive connections are the same on the bose unit as the monsoon. But on the other hand the grounds are different colors and there is only on common ground with the front and rear speakers. So how would you go about bypassing the grounds and would an aftermarket head unit with the wiring adapter also work with the wiring having only one common ground to the fronts and rears?
Old Aug 17, 2006 | 10:13 PM
throttlesteer's Avatar
Anybody else have any input as to NYC's question?
It looks like I'll be having to do some rewiring myself and trying to save some time. Thanks
phatbasslines
Jan 13, 2015 05:03 PM
cryptopsy
Aug 19, 2002 12:19 PM
Brian-94TA
Jul 31, 2002 02:52 PM
Mad_Ice
Jul 29, 2002 09:44 PM
