true duals
Old Jul 9, 2006 | 02:52 AM
Camster44's Avatar
Smile true duals
hey i was just wondering, i have a 3.4l and i just bought 80 series flowmasters and noticed they were split and then two tips but not true duals. is there a way i can get true duals and if so, what would be the difference?
Old Jul 11, 2006 | 02:02 PM
Tru2Chevy's Avatar
Re: true duals
True duals would be pretty expensive, as they would have to be custom made. Also, you would see no improvement, and your car would most likely be a little bit slower than with just a normal aftermarket cat-back (due to the increased weight of the true dual system).
- Justin
Old Jul 16, 2006 | 02:01 PM
red95camaro's Avatar
Re: true duals
I have true duals on my car took a bit of work but there are two cat with an "X" pipe and two mufflers under aswell. It really opened up the car in the top end. Pretty nice sound as well.
Old Jul 16, 2006 | 05:29 PM
jonathan_abilene's Avatar
Re: true duals
the 3.4 does not move enough air to require true duals.
what you gain in the higher rpms, you will definately loose alot more in the lower rpms
Old Jul 16, 2006 | 09:44 PM
Mr. Merk's Avatar
Re: true duals
pics of the true duals and the engine bay as well please!!
Old Jul 18, 2006 | 06:50 PM
Re: true duals
May be true for na but I have a vortech supercharger on my car moving air not really a problem
Old Jul 19, 2006 | 03:04 PM
user 647483's Avatar
Re: true duals
Tried it on a Heads/Cam 3.4, sounded like crap and didn't make any more power (Dynoed).
I had 2 2.25" pipes with an H where the cat should have been.
I was running Pacesetter headers.
I later added 2 2.25" high-flow cats, but it didn't help much.
http://i38.photobucket.com/albums/e1...tign/06_03.jpg
http://i38.photobucket.com/albums/e1...tign/22_19.jpg
I ended up going back to a single 3" with a single-in/single-out 3" Hooker muffler.
I used a 2x2.25"in/1x3"out high flow cat.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
