any f-body meets in toronto ontario?
Re: any f-body meets in toronto ontario?
Go to St. Thomas July 15th. The TFbM club is having a track day there and you'll have the opportunity to hear a bunch of different exhausts.
Or just go to www.ls1sounds.com.
Originally Posted by taner
so brett are you thinking of going?
ttyl
taner
ttyl
taner
but subject to change depending on my work schedule. Shall we organize a convoy?
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Originally Posted by Brett H
Tentatively...yes.
i can't say yes just yet, but i will look into it!
Taner: I'm a local boy at the St. Thomas track. My Camaro is undergoing some suspension work at the moment... so my car may not make it, but I'll be there. It would be great to see you run!
You may not run your best time there - the track has been #$^%# for traction most of the time this year. Regardless, I can promise to give you top quality video of whatever runs you make.
How have you and Roman been doing with your shop, BTW?
Taner: Brad and I might shoot over there for the day. I would like to go since I havn't even been able to test out my Mcleod and my new torque arm because I blew my posi carrier apart in Grand-Bend on the 2nd pass of T&T.
Give us a call if you end up going.
Jay.
Jay.
WHere abouts are you located? Im usually up for a cruise with a couple of my fbody/mustang buddies every wkend.
Originally Posted by CAMAROZ28AQUINO
is there any meets or shows where i can hear exhausts for myself to decide what to get??
wierd, i didn't see anything about the t'n't for tfbm at st. thomas. i will have to check again, i thought it was mustangs on sat. ???
http://www.stthomasdragway.com/schedule.html
It's there... both the Niagara Mustangs and T.O. F-bods on Sat. Last time (earlier this year) the London Mustang club was down there with the Toronto F-bodies.
Hope to see that beast run!
one important reason is for the right rear rotor that i must change before racing it along with the rear pads.
Probably not a great day to run anyways, with the forecast calling for 30+ and humid.
There was some confusion about this race date on the TFbM board, due to the fact that the event did not appear correctly in the printed St. Thomas schedules (although it is correct in the online schedule). Turns out that the event is definitely a go.
mark0006
Sep 14, 2015 12:35 PM
