Another best for Jason Warren
Old Nov 9, 2002 | 09:44 PM
twistedwedge's Avatar
Went to Bowling Green today....Car got 4.11's last week and we wanted to see what would happen...
60' 1.29
1/8 ?? time clock messed up
1/4 9.58@140.2
This was on a 300 shot (TNT plate kit)
the car also had a great day for 60 foot times.. best of 1.28.. also 1.29 and 1.32
Needless to say, he is pleased.. a good way to close out the season! The stock crank is still hangin in there!
Old Nov 9, 2002 | 10:07 PM
yellow Z28's Avatar
congrats to jason, thats totaly awsome!
Old Nov 10, 2002 | 07:15 PM
Derrick Redd's Avatar
When my stock bottom end goes I'm just getting forged pistons and Eagle H-beams. If the stock crank can live up to that......well you get the picture. Congrats to Jason.
Old Nov 10, 2002 | 08:02 PM
Guido's Avatar
Thumbs up
Kick ***!
Congrats!
Old Nov 10, 2002 | 09:04 PM
Jason Short's Avatar
Nice times Jason! On the stock crank no less either
Jason
Old Nov 10, 2002 | 11:16 PM
96z's Avatar
96z
Nice
Old Nov 11, 2002 | 12:46 AM
And who says GM cant make good quality cranks? lol I wouldnt recommend you counting on the stock crank holding up, keep in mind he only drives the car occasionally. We joke around all the time calling his car the time bomb. That is why he was so gung ho every time he raced this year...wanted to get a good clean pass before the crank took off down the track ahead of the car It is walking, but I guess as long as everything walks together it will work..
He still seems to think it has a little more in it, we shall see next year I guess. I will have some times to post also. Damn car has been down way too long..
Thanks
Old Nov 11, 2002 | 12:00 PM
Nostang 96z's Avatar
Man that car gives me some hope....that thing is flat out flying. What kind of fuel system is on Jason's car? Does he run a separate fuel cell for the nitrous or just one big pump? Stock fuel lines? Thanks for the info.
Matt
Old Nov 11, 2002 | 02:41 PM
blkchevyz's Avatar
thats very impressive
did he shoot all 300 at once or was it a progressive/2stage
Old Nov 11, 2002 | 03:06 PM
JeffB_94Z's Avatar
any other details? what kind of motor? what car? weight? tranny? etc! thanks
Old Nov 13, 2002 | 10:26 AM
BLWN1's Avatar
Yeah really, gives us details, or Better yet give us Mr Warren!
Old Nov 13, 2002 | 11:07 AM
A Small 427's Avatar
details or not....thats a hell of a 60'....i would like to go 1.2x's
Old Nov 13, 2002 | 11:37 PM
Allright, everyone. Here is the rundown on the car...
95 Z-28
10pt cage by Vern House at Performance Automotive (www.paracing.net)
BradCo. TH-400 w/brake (converter stalls to around 3800 on the nitrous)
stock LT-1 block bored .030
stock nodular iron crank w/factory 2 bolt caps
Stage 2 LT-4 heads and intake ported by Brandon Aders at
Total Engine Airflow (www.totalengineairflow.com)
TNT plate kit, jetted to 300 hp on the 9.58 pass (straight 300 all the way, no controller (timing or nitrous)) (All he does is pull out 9.9 degrees timing from the digital 6)
Comp cams solid roller (custom grind)
QA-1 adjustable coil overs
Travel limiters
Manual rack by Madman and Co.
Adjustable Torque Arm (MM&Co)
BMR: anti-roll bar, adj LCA, adj panhard rod
Spohn LCA relocaters
Aeromotive 500 gph pump supplies both motor and nitrous
-8AN supply, -6AN return
weight ??? est. mid 3200 range
Weld Drag Lites 15X3 front w/ ET Front
15X10 w/29.5X10.5 ET Drag out back (non tubbed)
Strange 12 bolt w/ spool and 4.11 gear
Mr Warren doesnt have a whole lot of spare time to get on the computer and chat, but he does appreciate all the compliments. I kind of act as his spokesperson so to speak. I hope this answers your questions. For updates and more info...Check out his page on my website... www.exit22.org/warren.html
Here is a link to the video
http://www.exit22.org/warren958.WMV
Thanks
Old Nov 14, 2002 | 12:48 AM
BLWN1's Avatar
Where is his car located in Kentucky?
Do yo all plan to take it to Clay City the 24th for Car Wars?
Old Nov 14, 2002 | 10:01 AM
dougg01's Avatar
What rpm is he shifting at...?
What stall is he using..? I saw you posted what it flashed to on spray....what is it supposed to stall on the 'brake...?
Is he using the brake on that launch and if so, what rpm was he leaving at...?
How is that T-n-T plate configured to allow a 300shot...? Most companies discourage going over 200-225hp on a TPI/LT1 manifold plate wet kit.
I already heard he is still using the factory PCM. That gives me hope.
What fasteners is he using in the bottom-end...?
Internal balance (?) and with what damper/flywheel combination...?
I'm just Mr. ask-a-lot aren't I. We're hoping to try running some high 9s eventually and my plans are very near where Jason is now. I'm part of the kyfbodies and was present for the wheelstand exhibition earlier this year.
Were the front end limiters the key to keeping it down...? A change in pinion angle...? What...?
Many thanks for the info. It'd be nice to have Jason come out to a club meeting or gathering and share some tips and ideas so maybe we can give him some competition.
