06-18-2006, 07:47 PM
LT1 Vortech T-Trim start up video
06-19-2006, 01:36 AM
Re: LT1 Vortech T-Trim start up video
what cam are you running?.. actually what is your whole set up haha C.R boost #? all that good stuff
__________________
99' 30th anniversary TA #0525.. good things too come
95' Trans Am.. A4-M6,M29, procharged 385ci
06-20-2006, 10:26 PM
Quote:
355, 8.5:1 Eagle crank,4340, Eag H rods ARP 2000 bolts, hell fire rings, Hi V oil pump, AFR 210 race ready heads, custom blower cam by Bret B, 230/244 .600 both sides LT4 intake welded and port matched by ME  LT1 intake did the Dizzy hole for me 58mm TB
84lbs inj
Gen 7 with dual sync
twin intake pumps
a few other things ..but you get the idea
06-21-2006, 06:00 AM
badass.. pretty wild set up man.. sounds wicked post of some vids of that beast, M6?
__________________
06-21-2006, 06:28 AM
Sweet setup. What's the dizzy hole and what does it do? Is really needed for a boosted car?
__________________
93 Blown, Poked & Stroked
06-21-2006, 07:16 AM
Yes the car is a m6 i will post vid...when i get the car rolling
06-21-2006, 07:20 AM
Quote:
the Dizzy hole is for a distributor..for the Gen 7 i am runing a dual sync so i can run sequential instead of Bach fire..
06-22-2006, 01:22 PM
So you got rid of the opti all together???
__________________
1995 Camaro: Dual belt mod GONE
2006 GTO: APS TT
1st APS 6 speed in the 10's @ 2008 East Coast Shootout 10.76@131
If you dont stand behind our troops, please feel free to stand in front of them
06-22-2006, 06:03 PM
Yep the opti is doing nothing other then plugging the hole in the front....
06-22-2006, 06:04 PM
I should add that this is a Harshaw Racing Engines (Brian) this is the same man who as built Tanners and Rommenss eng
06-22-2006, 06:59 PM
You are my new hero. PLEASE spill the beans on how you did that. I want this damn thing gone. If you could PM me I would sincerely appreciate it
__________________
2006 GTO: APS TT
06-22-2006, 07:55 PM
the opti is gone because i have the Accel Gen 7, With the Gen 7 you can install a distributor witch i did a dual sync, cam and crank Sig so i can run sequential instead of bach fire..
the MSD box is now my ing control modual
there are a few people on here that hgave done it....the look is cool
06-23-2006, 12:17 AM
06-23-2006, 08:06 AM
Can the dual sync dist. be run without the Gen 7
__________________
2006 GTO: APS TT
06-23-2006, 09:06 AM
hmmm... I it would take some serious work to get the cam and crank signal to work with the ecm, nothing is impossible in matters like these, but it sure would take some work and electrical engineering to build some form of converter or to rewrite how the ecm uses the signals available from the dual synch.. could be done I am sure.. but I don't have the electrical technical know how to do it personally. maybe some of our other more versed electrrical gurus could jump in?
sorry for hijacking Jeremy.. hijack off.. wicked might start a new thread on this?
Chris
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
