Anyone use a moates datalogging cable?
Old Jun 14, 2006 | 11:54 PM
93camaroLT1's Avatar
I tryed the cable from aldlcable.com with the belkin USB converter and it worked on datamaster while the engine was off but soon as I started it, it would automatically go to "lost aldl connection" and stop recording but then if I let the engine stall out soon as it would die out it would start recording again. I pretty much messed with everything possible on datamaster trying to get it too work (handshaking, timing, rec #'s per sec, etc, etc) and verified that the volts on pin were not going down on my Pin M once the engine started, and even tryed to use a alternative power source and it still didn't work, so I sent the cable back..
Anyone use this moates cable:
http://www.moates.net/cabl1-obd1styl...ctor-p-50.html
It costs almost $90 with shipping with the adapter, is it worth it? Does it actually work? Does it still need to use a power source (Such as the cigarette lighter) or does it just get power through the USB (I can't see a lighter plug on the picture..)?
Old Jun 14, 2006 | 11:55 PM
Re: Anyone use a moates datalogging cable?
The reason, i'm kindof interested in trying this cable out is it claims that it goes straight to USB from the ALDL.. But what is this "RJ" connector and the why the need for this converter box if this is true?
Old Jun 15, 2006 | 01:45 AM
tiznodd's Avatar
I am using it and it works great with Datamaster. I got mine through PCMFORLESS and it comes with both pieces for $90 (I think). Great tool to have.
Old Jun 15, 2006 | 01:46 AM
tiznodd's Avatar
It gets power through the USB.
G-BODYT56
Jan 14, 2022 11:14 PM
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
marlar98
Sep 19, 2015 07:53 AM
88IROC_Z
Jul 22, 2015 11:38 PM
