3rd gen rear end
Old Jun 12, 2006 | 11:04 PM
cc89formula's Avatar
3rd gen rear end
anyone ever put a 3rd gen rear end under a 2nd gen pontiac? ive got the disc break rear end out of my 89 formula that i would like to put in my 78 TA, thanks in advance.
Old Jun 13, 2006 | 12:12 AM
Stephen 87 IROC's Avatar
Re: 3rd gen rear end
It's a weak differential. A second gen is probably an 8.5 diff. I'm not sure the 8.2 was offered. The third gen 10 bolt is 7.5". The 89 will be 7-5/8" and still have the small 26 spline axles. 28 spline started in 1990. If it's a 9 bolt diff, it will be a stronger 7-3/4" diff but parts are hard to find and expensive.
As for if it will fit or not, you'll have to install leaf spring mounts and shock mounts. Not sure on the width. Second gen might be wider.
Old Jun 13, 2006 | 01:25 PM
Rice Killer87's Avatar
Yea,they are different in size like Stephen said...but what about taking the discs off the 3rd gen rear and adapting them to your 2nd gen rear?
Old Jun 13, 2006 | 03:56 PM
Tru2Chevy's Avatar
I don't think the 3rd gen rear is too much different in size (width) from a 2nd gen rear. I've seen plenty of second gens with stock third gen wheels on them that look factory fit....
- Justin
Old Jun 13, 2006 | 11:42 PM
stephen: its a 10 bolt and you are right it is a 7.5" and has the weaker 26 spline axles, but this cars never going to see a ton of power and isnt used for racing
Rice: i had thought about just putting the disc brakes on, but that car needs a new rear end, plus its got 2.56s and my 3rd gen rear has 3.27s
as far as size, i know my third gen wheels fit just fine on the 78, and the 2nd gen wheels fit just fine on the 89
Old Jun 14, 2006 | 10:48 PM
3.27? Are you sure that isn't a 9 bolt diff? GM didn't put 3.27 gears into a 10 bolt. The Borg Warner 9 bolt has 3.27 gears. It is the stronger diff but as I already mentioned, parts for it are expensive and hard to find.
Third gen diff identification.
10 bolts on rear smooth cover. 7-1/2 or 7-5/8" GM 10 bolt. Many variations through the 10 years of use as GM kept changing things.
9 bolts on rear cover with rubber fill plug. Australian BW 9 bolt. Performance diff option offered from 87-89.
10 bolts on rear cover with a metal fill plug in the cover. Very rare Dana 44 with 8.5" ring gear. Not a factory installation but was once offered through the GMPPC. SLP Firehawks had them installed.
Old Jun 15, 2006 | 01:03 AM
its a 10 bolt...atleast i think so...ill crawl under tomorrow and check, and i remember running the RPO codes for it and getting a 3.27
Old Jun 15, 2006 | 01:59 PM
Kado91Z's Avatar
it would be a 3.23 if it were a 10 bolt, 3.27 if it were a 9 bolt
Old Jun 17, 2006 | 02:46 PM
its for sure a 10 bolt, and i have the RPO's GW6:axle gear, 3.27 ratio and G80: axle positraction, limited slip. the original rear end could have been replaced, because im atleast the 4th owner of the car. i dont see one that says what rear end came with the car, whether its a 9 or 10 bolt. my RPMs are the same as a friend who has an 88 formula with the 9 bolt and 3.27s, but i guess they wouldnt be much different than the 3.23s....so now im a little more confused...
Old Jun 18, 2006 | 03:06 PM
Look for the code on the axle. It will be stamped on the front of the passenger side tube. It's hard to read. At least with that code, you'll know what originally came in that diff. Any previous owner(s) could have changed the internals or the entire diff.
If the rear cover has 10 bolts then it's a 10 bolt. If you really want to know the gear ratio, you'll need to pull the cover off and count the teeth. Just because an RPO or axle code says once thing, that doesn't mean that's what's in the diff. Parts can be easily swapped.
Chet1185
Feb 4, 2015 09:51 PM
RiverMutant96
Jan 30, 2015 09:21 AM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
