Fuel Injector Clips?
Old Jun 6, 2006 | 12:40 PM
twodollars's Avatar
Pulled off the old stock injectors last night, and in looking at the replacements they do not have the full circumfrence groove, so the stock clips won't work. Any idea on what I can use to hold them in? All I can come up with is bailing wire, and that aint cutting it.
Old Jun 7, 2006 | 12:40 PM
Z28SORR's Avatar
Re: Fuel Injector Clips?
I don't believe they are required. Your injectors can't go anywhere.
Old Jun 7, 2006 | 02:25 PM
Tex95Z's Avatar
I think you are right
Old Jun 8, 2006 | 06:27 AM
twodollars's Avatar
The only thing that I could come up with that would require them would be to locate all of them the same depth into the intake manifold, as they would be "locked" into the fuel rail at the same distance. But hey, you are right, they sure can't fall out or anything. I will just bolt it back together, and once connected pull them up into the rail as far as possible.
thanks guys,
Mark
Old Jun 9, 2006 | 01:03 AM
iansane's Avatar
So... Why does the factory have them?
Old Jun 9, 2006 | 06:27 AM
twodollars's Avatar
That's what I had been wondering...... Aside from locating each of the injectors the same in the rail, I don't see any need for them. But I think that having them all located the same is important for consistent fuel delivery from cylinder to cylinder, as far as spray pattern and delivery timing. But who knows.
Old Jun 11, 2006 | 08:16 AM
twodollars's Avatar
Well, now that I have put it together I understand. Without the clips, the injectors can actually bottom out in the rail, so when installed there is not enough penetration into the intake manifold. Especially since these were a tad shorter than the stockers. So, I had to position them myself to get them correctly sealed in both the rail and the manifold. But it works fine when all together.
Old Jun 11, 2006 | 10:46 PM
quickchicken's Avatar
when doing my motor swap i swapped to some SVO 19lbs and when i popped them in they would move around which botherd me. i could see vibs or a hard enough bump and then they would slide down for fuel to squeez out and that might poss cause a fire.
so i used my clips. take a good look at where the groove would be and you will see what looks as if it were filled in. take a remel and cut the groove. iv heard of someone else doing this, i think it was on the third gen list.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
