3.73's or 3.90's ?
Old May 26, 2006 | 10:34 PM
frankthetank078's Avatar
3.73's or 3.90's ?
I got a 93 z28 (auto) and i need to up my ratios...what is a good company to go with and what ratios should i get 3.73 or 3.90? would anyone no the spline, bolt and diameter i would need? Thanks alot guys
Old May 27, 2006 | 07:17 PM
MyShibbyZ28's Avatar
Re: 3.73's or 3.90's ?
First off, I don't know anyone who makes 3.90 gears. You can get 3.73 or 4.10 ratios for 10 bolts.
You need a set for a 7.5" or 7.625" 10 bolt carrier. They are the same gear, except one is 1/8" bigger. Depending on the carrier series you have now, that determines the series gear set you need. 2 series is a fatter ring gear, and 3 series is thinner. They have 27 spline pinions.
Old May 27, 2006 | 09:49 PM
Birdman7389's Avatar
Motive makes the 3.90 for our 10 bolt, Thunder has them.....
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
