what diagnostic prog. do u guys recommend
Old Nov 8, 2002 | 01:25 AM
whiteflame's Avatar
Just want to know what is the best diag. prog. out there so I dont get disappointed
Old Nov 8, 2002 | 07:45 AM
95Blackhawk's Avatar
Before we give you our opinions (because that is all they are), what are you trying to accomplish?
Ben
Old Nov 8, 2002 | 09:56 AM
whiteflame's Avatar
I want to be able to fine tune every aspect of my engine. I eventualy want to stroke and sc, but untill then just adjusting maps, times, curves for better performance.
Old Nov 8, 2002 | 02:37 PM
I use Datamaster along with TunerCat and I have not been disappointed. TC lets me create programs for racing, everday driving and for long hauls (disable PE for better gas mileage).
You have an OBD 1 car and they are the easiest to tune.
The setup with hardware will cost you around $250 - $300 but you will have hours of fun.
Ben
Old Nov 9, 2002 | 12:42 PM
ablackcamaro's Avatar
I'm in the market to buy a laptop specifically to run tuning and monitoring programs for my 95 formula lt1... what are the minimum requirements for the processor? Will a 200mhz running Windows 98 be sufficient? Thanks.
Old Nov 9, 2002 | 10:03 PM
It will work.
However, I use a laptop running at 500 Mhz and I cannot consistently get 10 data points per second. I am sure with a slower machine, you will have an issue with how much data per second you can acquire.
Ben
Old Nov 10, 2002 | 03:16 PM
Rufus's Avatar
If you turn off the real-time display updates while recording you will not have any problems getting 10 frames/sec which is the maximum the PCM protocol allows. I ran this a lot on a P166 laptop /Win98 and had no problems getting 10 frames/sec even with the display updates on. Probably depends on the laptop and if any other programs are running in the background.
Gary
Old Nov 10, 2002 | 11:15 PM
Never knew that trick Rufus!
Old Nov 11, 2002 | 03:34 PM
Thanks guys
squarehead
Jan 15, 2015 07:02 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
Desolate_Flux
Sep 11, 2002 04:06 PM
Fusion93Z
Sep 10, 2002 06:46 PM
Red97LT1
Aug 7, 2002 05:45 PM
