abs 3vs. 4 Channel
Old May 13, 2006 | 11:03 AM
radarb8's Avatar
abs 3vs. 4 Channel
Has any one put a 4 channel abs rearend in a 3 channel car by just tapping in to the abs sensor at the wheel on the 4 channel ?
Old May 20, 2006 | 07:32 PM
Silver's Avatar
Re: abs 3vs. 4 Channel
have you learned anything yet? i have a 4ch rearend i picked up for my 3 ch car and i'm a bit sad.
Old May 20, 2006 | 10:45 PM
radarb8's Avatar
Not yet . I guess it must not be something too many pepole have tried to do
Old May 21, 2006 | 01:27 AM
Silver's Avatar
well i read where you can take one sensor from a 4 ch and run it to the single input for a 3 ch. also, found the abs inop light delete here: http://www.bfranker.badz28.com/fbody/abslight.htm
my question now is if i leave the rear unplugged altogether does the front abs still work...
Old Feb 13, 2007 | 12:35 PM
seawolf06's Avatar
I know this is old, but I want to know this too. I was told no.
Old Feb 13, 2007 | 01:10 PM
respectirocz's Avatar
i believe all abs systems have a failsafe where if the abs light is on, the abs system is disabled, there is no partial abs, or front only abs
Old Feb 13, 2007 | 01:48 PM
Zeetwentyfate's Avatar
yeah you cant make a 4ch and 3 ch work together the speed of the rings the sensor will be different and there fore will not work.
Old Feb 13, 2007 | 02:38 PM
seawolf06's Avatar
Ok, I just wanted to see if anyone had figured out a way.
IndyZman
Oct 22, 2015 02:17 PM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
Bxlt1
Jul 18, 2015 02:48 PM
