LCA and Relocation brackets installed
Old May 10, 2006 | 12:05 PM
ZL1modified's Avatar
Question LCA and Relocation brackets installed
i am very happy with the results, however about 200 i started getting a rubber against rubber typ of sound when i hit bumps (here in PA thats very often) and i was curios to see what it was so i stopped the car and got out and started pushing down on the back of the car. well every time i did it i got that same sound.
now is this a common problem when you install brackets and lca's?
and is there a solution?
the shocks are brand new and so far it is only the drivers side making the noise.
Old May 10, 2006 | 02:44 PM
93redBirdMan's Avatar
Re: LCA and Relocation brackets installed
did you grease the LCA's and relos?? That could be it..
Old May 10, 2006 | 02:48 PM
the lca's came greased from spohn.
and i dont see where or how you would grease the relos.
Old May 10, 2006 | 05:14 PM
seawolf06's Avatar
I'm guessing they're rubber bushings? You're putting more pressure on everything, so it makes sense that it would make a little more noise than before.
Old May 10, 2006 | 06:13 PM
teke184's Avatar
are you sure everything is tightened down correctly??
Old May 11, 2006 | 05:22 AM
pretty sure but i will triple-check.
thanks guys
so i take it that the lca's and reloc. brackets on a car with stock ride hieght will not affect your shocks?
Old May 11, 2006 | 07:16 AM
teke184's Avatar
nope...shouldn't affect them at all...
not saying they didn't finally wore out enough to start making noise...as coincidence...but it shouldn't be caused by the mods
Old May 11, 2006 | 10:48 AM
By greased I didnt mean the stuff you put in a grease gun. They didnt give you two little packets of grease for the ends of the bushings on the LCA's? I'm not saying thats your problem, but I "greased" mine as I am describing and no noise..
Old May 11, 2006 | 11:17 AM
they didn't give me any.
however i have some from a bushing kit that i got so, i guess i'll rub some on and see.
thanks 93redbirdman
Old May 11, 2006 | 08:09 PM
mook99TA's Avatar
Make sure you don't pre load the LCA's because if you tightend everything with no load on the LCA's can cause the squeeking and possibly ruin your bushings.
Old May 12, 2006 | 01:45 AM
smoknta's Avatar
Yeah...you need to tighten them with the suspension loaded. This will take the pre-load out and possibly get rid of any binding.
Old May 12, 2006 | 06:21 AM
yeah i tightened them with the car in the air.
so should i be alright if i loosen them up and tighten under load?
thanks alot for the info
Old May 12, 2006 | 07:05 AM
cg4743's Avatar
I just install my LCA's with the brackets and I had no problems. Everything was done under load as all 4 tires were set on blocks. Just a question, but did you weld in the brackets? I put in new shocks at the same time and all seems well. The LCA's along with a few other things I believed hepled me get my 60' times down from 2.0 to 2.1 to a 1.82 to 1.87 I still would like to be lower but that's better. I'm wondering if my new TA would help with that? I haven't had time to install that yet.
Old May 12, 2006 | 07:47 AM
yes there welded on and bolted on.
i think its the load thing seems to make scence.
cg4743, how much did they take off of your 1/4 time?
Old May 12, 2006 | 08:38 AM
cg4743's Avatar
I haven't run a 1/4 mile track yet hope to tonight. My local track is an 1/8 mile. Hard to say on that time since several other mods were done at the same time. I was running a 8.38 with the SC and a stock manifold and then and 8.45 with the LT's and cat-back. Got to the 8.03 after the Susp. work, Mad Z28 tune, Ported intake and 50# injectors. Before the Sphon parts I couldn't get below the 2.0 mark with my 60'.
