Composite rotors vs cast rotors?
Old May 4, 2006 | 11:51 AM
Randy1994's Avatar
does anyone have any idea if the composite slotted rotors are as good as drilled&slotted cast rotors. any feed back is welcome.
Old May 4, 2006 | 08:24 PM
Bud M's Avatar
Re: Composite rotors vs cast rotors?
What do you mean by composite rotor?
Old May 4, 2006 | 09:07 PM
95Z28A4's Avatar
The OEM style rotors on my Jeep Cherokees are composite. The iron disc is cast onto a stamped steel hat. Link below is a pic of a Raybestos PG Plus rotor for a Jeep Cherokee.
http://www.partsamerica.com/product_...ray/7142-2.jpg
Old May 4, 2006 | 10:02 PM
Greed4Speed's Avatar
I believe the stock rotors are like that and they suck!
Drilled slotted rotors are eye candy only. Do not buy them thinking they're the epitomy of braking performance. Instead invest money in better pads and get some heavier stock replacement rotors.
Old May 5, 2006 | 10:40 AM
Xride's Avatar
Very true
Also when you drill and slot a cast rotor you weaken it, and they will get stress cracks.
If you want the eye candy look make sure they are cast with the holes at least.
But if you ask me it just reduces the surface area that the pad can contact, and modern pads dont have gasses that need to be vented.
Old May 5, 2006 | 11:29 AM
Dave K's Avatar
Not all 2 piece rotors are bad... floating rotor brake designs are pretty much the top of the line for street cars... but the rotor you linked to aint in that category. At the inexpensive end of the spectrum I think your best bet is a traditional one piece design.
Old May 6, 2006 | 12:32 AM
Randy1994's Avatar
thank you for all your inputs. i am getting a set of drilled and slotted rotors for my 94. i will let ya'll know how they perform on my car. i got them at a great deal.
Old May 6, 2006 | 08:59 AM
from WPD???
Old May 6, 2006 | 09:14 AM
StephenDeli22's Avatar
I would agree with you that drilled slotted rotors are only eye candy for the street. But if you reduce the surface area that the pad contacts, you get more pressure on the rotor. So theoretically the pad would be grabbing on that rotor a bit harder.
Old May 6, 2006 | 11:23 AM
That theory has flaws.
Old May 7, 2006 | 01:30 AM
Severous01's Avatar
i'll ask one question and tell my side of the answer.
WHAT KIND OF ROTORS DO F-1 SUPERCARS USE, CIRCLE TRACK CARS USE, AND NASCAR CARS USE?
answer is blanks. because they are cheap, work just fine under extreme conditions, and don't crack under stress.
blanks are used for all serious racers because they are just fine for what they are used for. they are used for extreme braking and dont need the reliefs for "gasses" that are formed from technology that was outdated years ago. they dont need to be "cooled" by air flowing insid the wheel because they have vents in them. blanks are fine for a NASCAR driver and they are fine for me. i just went with the c5 brake upgrade and i bought brembo blanks for it. i'm sure i'll be fine.
Old May 8, 2006 | 09:28 AM
Bud M's Avatar
The caliper applies as much pressure on the pads as the hydraulic pressure makes it apply. It doesn't know whether there are holes in the rotor. Bottom line is there is less contact area between pad and rotor, so brake performance decreases. In all likelyhood pad life decreases slightly too.
Having said that, what's so bad about a little bit of eye candy on a street car? As long as you understand that its functionally a step backwards, if it turns you on, do it.
LT14LIFE
Nov 15, 2015 06:22 PM
93 RedBird
Nov 15, 2015 08:24 AM
HibachiZ28
Nov 6, 2015 12:53 AM
jayblev95
Sep 26, 2015 09:44 PM
Z Power
Sep 19, 2015 11:19 PM
