Speed Sensor DTC comes on after hard launch
Old Apr 28, 2006 | 03:18 PM
camaro81's Avatar
When I made my first pass at the track after having my transmission rebuilt, I cut a 1.75 60' and it took off great, but it wouldn't shift into 2nd until I lifted. Datamaster stoped reading mph and the window lit up with a DTC from the transmission. The DTC's I get are:
22-TPS Sensor Low
72-Output Speed Loss
I reset the computer and it ran fine on the next pass.
That was 3 months ago and today I'm in Maryland for the Super Chevy Show doing test and tune. I decided to spray a 50 shot off the line to see if I could lift the wheels (which I did!) and it left hard, cutting a 1.649 60' and wouldn't shift into second, the datamaster started beeping again with the same DTC. I reset the computer and its running great again. Also, no check engine light ever came on.
Why would my speed sensor crap out on a hard launch? What can I do to prevent this? Could anything have gone wrong durin the rebuild that would cause this?
Old Apr 29, 2006 | 08:07 PM
Blownbird355's Avatar
Re: Speed Sensor DTC comes on after hard launch
Sounds like the dreaded 1-3 shift. How are you launching, what do you stall car to?
Old Apr 30, 2006 | 06:10 AM
camaro81's Avatar
I usually stall the car to 1500 and it flashes to about 3600. I forgot what the nitrous flashed it to though. I contacted my tuner and he said he has a fix for it, he said it was caused by a bad OBD I reaction to the converter or something like that.
Old May 2, 2006 | 09:23 AM
If you want to try to stalling only to 1k and launch that worked for me.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
jj_burchiel
Mar 21, 2015 12:51 AM
mark0006
Dec 25, 2014 09:50 PM
