Jet sizes and tuning
Old Apr 24, 2006 | 03:48 PM
nfa's Avatar
nfa
Nitrous works recommended the use of .052 n20 and .033 fuel jets to achieve a 125 hp shot. However, plugging in the n20 jet and bottle/fuel pressure into an online jet calculator results in a recommendation for a .029 fuel jet. Does the nitrous works recommendation sound really conservative to you and would I stand to gain from leaning it out somewhat? I also installed a racetronix pump so would this fatten up the a/f from the stock pump?
Mike.
Old Apr 25, 2006 | 11:18 AM
Legion's Avatar
Re: Jet sizes and tuning
Nitrous Supply recommended the same jetting combo for their 125 shot. I tuned the N2O on the dyno and with recommended jetting it was REALLY rich. we kept putting smaller fuel jets to get the AFR right. I think they use conservative jetting to prevent someone from killing the motor if their fuel system isn't up to par. funny thing is the HP didn't really increase when we got the AFR's on track, but torque just kept on climbing.
Greg
Old Apr 25, 2006 | 07:47 PM
nfa's Avatar
nfa
What fuel jet did you end up using???
Greg
Old Apr 26, 2006 | 11:02 AM
Legion's Avatar
we ran out of small jets, so AFR's are around 10.75 through the rpm's with a 30 fuel jet. we estimate it probably needs a 28 to be dead on.
Greg
Old Apr 26, 2006 | 11:44 AM
MetallicTrans96's Avatar
I use nitrous works and i am using 150 wet kit. I followed the specs and dynoed and it was fine..it was alittle rich but i guess thats fine so i dont have detonation
Old Apr 29, 2006 | 10:11 PM
nfa's Avatar
nfa
how much timing, if any, did you take out? What A/F ratio were you at w/ the 150 shot?
Old May 1, 2006 | 11:04 AM
I think i was around 11 on the a/f and i cant tell you exactly how much timing...but its 2 for ever 50 so somewhere around 6
HectorM52
Jul 30, 2017 11:46 AM
HarleyZ28
Oct 5, 2015 06:23 AM
RickRay
Events and Cruise Spots
Apr 23, 2015 02:50 PM
Fatdog2
Mar 31, 2015 06:50 AM
