Is it nescessary to vent both valve covers?
Old Apr 12, 2006 | 06:58 PM
BMAN'S SCZ's Avatar
On my last motor I ran breathers in both covers. Now on my new motor I have LT4 composite covers. I was thinking of drilling out the driver's side to vent some pressure also. Is it necessary to do this? Is one side good enough? I will only be running around 8# of boost on a 9:1 compression motor.Also I did a search and it is 50/50 on hooking the breathers lines to the inlet of the blower. What do guys think of this also. Thanks guys for any replies.......John
Old Apr 12, 2006 | 07:46 PM
97WS6Pilot's Avatar
Re: Is it nescessary to vent both valve covers?
I leave the PCV hose stock and run the breather hose to the inlet of the blower. I had to put an air compressor water separator in the breather hose to keep oil vapors from getting into the inlet of the supercharger. Every so often I empty the oil back into the crankcase.
When I ran a straight breather filter I would get oil on the valve covers from high rpm runs. So I switched to my current setup.
Another good thing is that I pull a vacuum on the crankcase at Wot and at idle.
Old Apr 13, 2006 | 08:46 PM
BMAN'S SCZ's Avatar
Thanks for the reply. Should I run both valve covers like that or is one sufficient? Thanks,,,,,,,John
Old Apr 13, 2006 | 08:57 PM
97WS6Pilot's Avatar
One will be sufficient. No need to hack up those new composite valve covers. Where did you buy them? Do they say Corvette on them?
Old Apr 14, 2006 | 08:46 AM
BMAN'S SCZ's Avatar
They came on a long block I purchased. I know pace performance parts sells them for like $94 a piece plus screws and gaskets. No, they do not say anything on them. I can send some pics if you like.Thanks again....John
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
