ABS Inop light coming on from stereo?!?
Old Apr 11, 2006 | 01:29 AM
dthomas's Avatar
I was adjusting the EQ on my stereo today, and giving it some good burps up to 149dB and it set the ABS Inop light. This has happened before when I have pushed it a bit. Mostly I am trying to figure out if it has to do with the voltage drop when I am turning it up, or if it is from the vibration. With the car running, it usally doesn't go much under 11.4volts when I am pushing it.
Thanks,
David
Old May 4, 2006 | 11:22 PM
fragglerock's Avatar
Re: ABS Inop light coming on from stereo?!?
Same problem here, I just had a 300w amp and a 480 watt amp installed. The abs light comes on about 10 after start up and even killed the battery at one point where I couldnt start the car, would only click.
I put a new battery in it and it helped but still came on after about 30 minutes. It hasn't cutoff on me yet.
The one thing I'm noticing is that he ran the main power wire from the 2 amps in the back to a red little distro box by the battery instead of straight to the battery, would this cause harm?
Thanks for the help on this.
Old May 4, 2006 | 11:50 PM
n/m found this: Seems like it's prob the alternator
Originally Posted by JJJ93z
i just got a duralast gold one from autozone, remanufactured its a 124 amp one, the volts stay above the middle line even when the subs hit, except when i am stopped then it drops a lil below the line, not much though, but if i turn my stereo down it pops back up there! it has a lifetime warraty with it, but i am getting rid of my z by the middle of summer for a 35th anniv. edition. , thanks for all the help guys i dont know what i would do without this board!
Old May 5, 2006 | 11:20 AM
dthomas's Avatar
Yeah. I went and got a new battery and it has cleared it up for the most part. If I do any quick burp's with test tones it will still set it and the Airbag light. But as for normal conditions, its fine.
Old May 6, 2006 | 11:18 AM
argh... I was driving today and I have a new battery, I started seeing the voltage drop on the gauge, I tried to make it home and it died on me. I coasted into a parking lot and now the key won't turn all the way back so I can get it out and it won't start. I tried a new battery and jumping it. I get a faint wine but not even clicking. The beeping because the keys are in the ignition is working even the stereo turns on. I can't get the keys out of the ignition because they wont turn back all the way. I have checked all the fuses in the dash and under the hood(in the fuse block with the big abs fuse) unless there are others to check.
Could someone help or forward to someone who can? Thanks!
Old May 6, 2006 | 12:45 PM
nervekiler's Avatar
i woudl like to know what equipment you are running to burp 149db.
Old May 6, 2006 | 01:28 PM
fbodylover4ever's Avatar
you should seriously consider a separate battery just for your system.
Old May 7, 2006 | 12:20 PM
dthomas's Avatar
I am running a modified Earthquake PHD2 amplifier and 2 older Audiobahn AW1200's. I have them ran at 1 ohm. The box is 2.5 cubic feet per sub tuned to 37hz.
With music I have done 148db legal at the dash, and with test tones I have done 150.5db legal at the dash.
Old May 7, 2006 | 12:22 PM
dthomas's Avatar
I wouldn't. Unless your are playing the stereo with the car off alot. The 2nd battery would just become a bigger load to the alternator leaving him less power for his amps.
transam_388
Mar 15, 2015 11:53 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
blac94Z
Dec 2, 2014 12:09 PM
isimplyexist
Mar 25, 2004 08:06 PM
