04-07-2006, 04:31 PM
fuel pump not running tried changing relay did not work
ok car wont start but turns over fine has spark off of coil lead but fuel pump not operating. I tried to change the relay and same result. i get 12v + on i believe the orange wire witch is power to relay but i can not find any power going out to the pump. looking at the relay wiring diagram i should have power out to the pump from the gray lead going to the back of the car is this correct? and if i connect 12v positive to the prime connector will that make the pump run regardless of the relay?
also anyone change the pump? any advice on this job? with my multi meter i only found 2vdc on one other wire and nothing else how can i make sure the relay is functioning befroe i think about dropping the tank to look at the pump.
thanks in advance for any advice you can give.
Ed
__________________
1996 Z28 A4 Ragtop
04-07-2006, 04:56 PM
Re: fuel pump not running tried changing relay did not work
You'll have to apply power and ground to two of the terminals (the coil) and then check for continuity on the other two terminals.
BTW I think the relay is ground side controlled, so it would always have power. You might want to check a wiring diagram to make sure. I'd trace the problem around with a multimeter before dropping the tank. You could always jump the wires that go to the pump at the relay to try to split the problem up.
__________________
Green 95Z- SOLD
Navy Blue 98Z- the usual bolt-ons
04-09-2006, 02:20 PM
thanks green demon im looking at the wiring diagram and the wire to thje pump through the level sender is grey so you are saying jumper the power wire back to the pump to see if it runs. if it runs then wiring bad and if iot does not then the pump is bad. is that the idea? also the fuel pump prime connector what is that can anyone tell me. thanks again
ed
__________________
1996 Z28 A4 Ragtop
04-09-2006, 05:03 PM
ok did some searching and found out where and what the fuel pump prime connector is. tried giving the pump prime connector 12vdc from the battery and it did nothing. no noise could be heard from the pump in my quiet garage. I just read where the ground is and also where to test the fuel pump connector by the left rear wheel so i will test there in just a minute.
does the key switch need to be on when connecting to the prime connector or does that matter?
__________________
1996 Z28 A4 Ragtop
04-09-2006, 05:51 PM
I had a similar problem which I thought was the relay; infact it turned out that the ground wire for the FP went bad. I cut the ground, crimped on a ring terminal and re-grounded it; works great now; never had a problem since.
__________________
Words to live by: "Never have a war of words with an unarmed man"
An engineer needs a wife and a mistress. That way the wife thinks he's with the mistress, the mistress thinks he's with the wife, and he can go to the lab and get some work done!
04-21-2006, 12:27 AM
Quote:
Where is this ground at?
__________________
96 Camaro Z28
69 Firebird
89 MX6 GT 4WS
12-18-2006, 09:10 PM
did you give it positive or negative? where do you test it by the rear left wheel?
__________________
97 Z/28 M6
Stock Rebuilt 353 LT1
CC503, Pro-Mag 1.52's , 986's, Jeff Creech Tuning, B&M Ripper, LS1 DS, LT4 PP, McLeod Single Disc, Jet Hot Lt's, Off Road Y-Pipe, BorlaMouth, SLP CAI, Free Mods, 235 Nitto's
12-18-2006, 11:42 PM
Check power and ground at the fuel pump connector. Remember you will only have power to the fuel pump for about two seconds with the KOEO. If you have power and ground there you need a new fuel pump.
__________________
1999 Cougar - DD
1997 Z28 A4
12.805@106.54
JetHot Lts,ORY,SLP LM,TB Bypass,LT4 KM,160* thermostat,!HVAC, Motive 3.73's,Fuddle 3200, Hotcam, K&N Cai madz28 tune
12-19-2006, 07:36 AM
I have seen a couple times the bulkhead connector get jacked up. It's an easy check.
12-19-2006, 08:31 AM
Quote:
Happened to me.
I also had my fuel pump go out on me as well though
__________________
'97 Bright Green Metallic Z28 A4
Current best 11.14 @ 120.06 1.542 60' (Best MPH 11.18 @ 120.33)
355 LT1 - LE2 Heads - LE3 Cam - All the Bolt Ons - Moser 9" 4.11's - CPT Pro Race 4L60E - Yank PT4000 - 3" X-Pipe/Bullets
12-19-2006, 11:06 AM
It is very unlikely a wiring problem. I would check the fuse and leave it at that. Next unplug the wiring connector back by the rear left wheel and apply power and ground directly to the appropriate wires that run the fuel pump. If you dont hear it running, the fuel pump is the problem. You'll need some long jumper wires.
I cut a hatch to replace mine and I'm glad I did because I have had 2 fuel pumps go bad. This is a good opportunity to get a racetronix setup.
__________________
97 WS6 TA, Rebuilt 355, 15psi Procharger F1A. Sold http://www.cardomain.com/ride/2373730/1
93 Turbo Corvette, Polo Green, Accel DFI Gen 7, Stock internals, Roller rockers, 218/224 Cam, Meziere EWP
12-29-2006, 05:20 PM
mine is doing the same thing i am wondering what wires i have to apply power 2 to make the fuel pump run and if it doesnt then i will cut the hole and go from there. and where was that ground that 97FormulaWS was talking about because i will check that 2. thanks
12-29-2006, 07:18 PM
ok it works when i use the factory jumper wire in the engine bay so i am not sure what that means does that bypass the fuse and relay and computer. i am not sure where to go from here so any input would b great. thanks
12-29-2006, 08:53 PM
well a couple weeks ago i got a new ecm because i am throwing ghost codes and i was told this might fix it. so after i have tried everything i put my old ecm back in and away i go. so i am going to try to get my money back so we will c what happens. i will keep u everyone in the loop. thanks
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
