Idle messed, and speedo no working
Old Apr 5, 2006 | 05:31 PM
StreamlineZ28's Avatar
Last week i broke my torque arm and after i fixed it, my cars speedo isnt working. not sure if that hasnt anything to do with it or not.
anyways that isnt the main problem, when i start my car it runs fine idle is all good around 900rpm then as soon as i start driving it when i comming to a stop the idle goes down to about 400 and stays there and feels like it wants to stall. it has twice. The check engine light usually comes on after a few minutes and once the check engine light comes on the car starts to idle at stops properly again
any ideas of what might be wrong?
Old Apr 5, 2006 | 05:36 PM
Dave89IROC's Avatar
Re: Idle messed, and speedo no working
sounds like the VSS or connector/wiring was disconnected/damaged when the torque arm was fixed(no VSS signal to the PCM will do what you are describing)
Old Apr 5, 2006 | 05:44 PM
thanks i may have knocked it with the torque arm, it was a pain to do by myself. ill check that
blac94Z
Feb 10, 2015 11:02 AM
Gtpguy
Jan 26, 2015 04:50 PM
Britbilly
Jan 7, 2015 08:49 PM
Queens94z28
Nov 20, 2014 06:03 PM
