Few Suspension Questions:
Old Apr 1, 2006 | 07:57 PM
DontMixWithRice's Avatar
1. Where can I order a good "rag joint" bushing
2. Where can I buy energy suspension bushing for the upper and lower control arm?
3. I need a better explanation of the ball joint, and what is involved in maintenance.
Its a little long winded...
Thanks guys...
Old Apr 2, 2006 | 12:57 AM
97FormulaWS-6's Avatar
Re: Few Suspension Questions:
1) why do you need a new rag-joint? if it's bad, typically that's just a factory or typical parts store replacement.
2) www.summitracing.com www.jegs.com
3) Ball joints connect the A-arms to the Spindles; they normally are either good or bad; they should require no maintance except to grease them through the fittings once in a while.
When they fail they are loose, if the ones on your car are solid and only rotate/swivel and aren't loose, then they are fine.
Mar 13, 2016 03:37 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
football4life
Oct 4, 2015 07:48 AM
97blackformula
Aug 27, 2015 06:02 PM
force10
Jul 30, 2015 04:56 PM
