panhard question
Old Mar 28, 2006 | 03:55 PM
DiabloGT's Avatar
panhard question
im about to order a umi adj panhard rod, and i was wondering, is it really easy to install like they say? and when its on, how can you tell if the center is perfectly centered? and if my car isnt lowered, its just that the tires are wider and one side rubs, will i just have to bolt it on without worrying about adjusting it?
thanks
Old Mar 28, 2006 | 04:06 PM
MPB70350's Avatar
Re: panhard question
20 mins to install it piece of cake. if you arent lowered then adjust it to the same length as the stock one and you should be fine.
Old Mar 28, 2006 | 04:09 PM
2000GTP's Avatar
The hardest part would probably be breaking loose the old rusty bolts,but even that is not to bad.
slowpoke310's Avatar
its easy 2 install
but if he's already rubbing on one side of tires, he'll prob, have to adjust it.
its simple and once u have it on jacks, u can literally see the adjustments, by just eyeballing
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Fatdog2
Apr 10, 2015 12:07 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
