Ball Joints...
Old Mar 22, 2006 | 07:03 PM
ChrisUlrich's Avatar
Ball Joints...
Do they sell aftermarket Balljoints? I did a little search and didn't anything on aftermarket ball joints.
Do they really only sell lower ball joints with the control arm and that's all?
I am doing the LS1 Brake Conversion and figured I might as well put on new ball joints because the car has 123k.
Does anyone know where to get them fast? Anyone know a reasonable price for them?
Old Mar 22, 2006 | 07:07 PM
2000GTP's Avatar
Re: Ball Joints...
Wrong forum!
But I believe Moog sells upper and lower replacement balljoints.
Old Mar 22, 2006 | 07:10 PM
Re: Ball Joints...
Yea you're right... I should of put this in the suspension forum. Sorry Fred... :-/
Old Mar 22, 2006 | 08:10 PM
OBE1 95Z28's Avatar
Re: Ball Joints...
Moog carries both the upper and lower ball joints. Uppers are easy to replace; lowers can be a pain to press in and out.
Old Mar 22, 2006 | 08:20 PM
Re: Ball Joints...
You think I can get them from an Autozone or Advanced Auto? You think I should if I can?
Old Mar 23, 2006 | 09:43 AM
OBE1 95Z28's Avatar
Re: Ball Joints...
I have know idea how mechanically inclined you are, so I can't provide a recommendation.
Old Mar 23, 2006 | 10:16 AM
Loadre's Avatar
Re: Ball Joints...
Lowers are a BITCH.
Old Mar 23, 2006 | 11:06 AM
8cylinders>4's Avatar
Re: Ball Joints...
you can get both the upper and lower for an lt1 car at advance auto i know because i work there while im in college i dont remember the prices though
Old Mar 23, 2006 | 11:27 AM
LiENUS's Avatar
Re: Ball Joints...
I have some moog balljoints in my lcas no noise or anything but yeah a bitch to install.
Old Mar 23, 2006 | 12:04 PM
marshall93z's Avatar
Re: Ball Joints...
I put some lowers in mine from Advanced Auto.
Old Mar 23, 2006 | 12:42 PM
LiENUS's Avatar
Re: Ball Joints...
Mine were from CarQuest
Old Mar 23, 2006 | 12:48 PM
93ZM6Tally's Avatar
Re: Ball Joints...
As mentioned befor the uppers are easy, the lowers are a PITA. I have my own press and they're still difficult because of the angles created by the lower A-arm and the fact that there isn't much material on the "outbound" side of the ball joint. If you have access to various press fixtures and different diameters of pipe it's a little easier. I've also used the ball joint press tool that you can rent from AZ. It's nothing more than a large c-clamp with round fixtures, it works but it ain't fun.
Old Mar 23, 2006 | 02:51 PM
Loadre's Avatar
Re: Ball Joints...
Word. I used the ball joint rental tool from AZ too. Not a fun experience.
Old Mar 24, 2006 | 01:08 AM
Koby's Avatar
Re: Ball Joints...
If I ever replace my ball joints they are coming in a pair of BMR replacement parts. The front shocks were enough for me......
Old Mar 24, 2006 | 04:13 AM
RE AND CHERYL's Avatar
Re: Ball Joints...
upper and lower are both available from Advanced Auto Parts. The Upper is $20-40 and the lower is $10-20. Price range is depending on which quality ball joint you get.
