engin help
Old Mar 16, 2006 | 06:47 PM
Irocn88's Avatar
engin help
im planning on running about 800HP with nitrous, what will i need to do to my computer? and what size injectors should i run?
Old Mar 16, 2006 | 09:58 PM
89Vert's Avatar
Re: engin help
Stock 165 MAF ECM will not support that kind of hp,
Stock 730 MAP ECM is alot better then MAF but I'm not sure what kind of power it will support,
DFI is going to be your best bet
you'll need at least some huge injectors like 60# or something and a serious fuel system to supply it
Old Mar 16, 2006 | 10:10 PM
thirdgenrallysport's Avatar
Re: engin help
whats the motor? 800Hp eh..
Old Mar 16, 2006 | 10:24 PM
Irocn88's Avatar
Re: engin help
i have a built 350 4 blot short block and a 400shot of nitrous , i was hoping to keep the computer but i might just go carb,
Old Mar 16, 2006 | 10:34 PM
89Vert's Avatar
Re: engin help
what intake you planning on running?
if you stay MPFI
Old Mar 16, 2006 | 11:58 PM
Re: engin help
if you stay MPFI
what he said. i dont think a tpi will support 800hp.
Old Mar 17, 2006 | 02:14 PM
89Vert's Avatar
Re: engin help
My cousin built a 383 running a stock TPI intake, it ran 400hp at the flywheel,
but siad there wouldn't be much chance it getting 500hp out of it,
he knows his stuff, builds sprint car and drag car motors for a living
Old Mar 17, 2006 | 03:09 PM
Irocn88's Avatar
Re: engin help
well what intake can i run??
Old Mar 17, 2006 | 03:21 PM
Irocn88's Avatar
Re: engin help
i have 550hp at the wheels now out of my tpi
Old Mar 17, 2006 | 03:40 PM
89Vert's Avatar
Re: engin help
I'd have to see a dyno sheet AND video to belive that,
who tuned it?
if your 88 and running stock MAF setup, its almost impossible unless your car has terrible drivabilty
Old Mar 17, 2006 | 10:00 PM
Tremo's Avatar
Re: engin help
What crank, rods and pistons you using? 800 hp will send stock rods through the pan.
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
Feb 10, 2015 10:36 PM
centric
Aug 15, 2002 09:04 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
