edelbrock carb and 700R4
I just rebuilt my L98 350 and found a new 700R4 for my 89 Camaro. I've got a Holley Street Dominator manifold on top (squarebore) and am looking to buy a new 600CFM Edelbrock for the simplicity and reliablilty.
My question is: which corrector lever and throttle cable/TV cable bracket do I need? I looked up the parts on Summit and they look about right, but I'd feel better asking someone who has a similar setup what they have. Right now, I'm looking at EDL-8036 and SUM-700203. Will these work for me?
Re: edelbrock carb and 700R4
I'm still in the process of converting from TPI to carb. One place ive been putting a lot of thought into trying is bowtieoverdrives.com. Little more expensive than summits but i like the design more.
Not a fan of the way the edelbrock carbs perform. I just bought a Holley 750 DP to replace my old Q-jet. A Holley 650 vac. secondary carb would be pretty good for your application.
- Justin
- Justin
I already have a Holley 650 VS, but I need a spreadbore to squarebore adapter to use it. Had I done my research before I bought an intake, I wouldn't have this problem. I realize it's not a problem to get an adapter plate, but I'm not very confident with tuning a carb, so I'd rather just get one that's good to go out of the box and doesn't need adjusting frequently like Holleys apparently do.
I know someone on this board must have a similar combo on their car. Edelbrock carb with 700R4 behind an SBC. What did you have to do to make the 700 shift properly? i.e. bracketry and/or geometry corrector?
Holley's don't need frequent adjusting.
Originally Posted by five7kid
I don't know what you mean by that. Both the Holley and Edelbrock are squarebore.
I present to you: Holley 650 spreadbore style
link to actual page: http://www.holley.com/0-80555C.asp
All I wanted to know was which bracket and/or geometry corrector to use with the 700 and Edelbrock 600 cfm squarebore. I don't really care what anyone else's opinion on either Holley or Edelbrock carbs is.
