C-Clip Rear Ends
Old Mar 8, 2006 | 10:42 PM
69gto96z's Avatar
C-Clip Rear Ends
How hard is it to replace a c-clip in the rear axle? Could I buy the clip at a local parts store or would it have to be ordered?
Old Mar 8, 2006 | 10:51 PM
mystic-t/a's Avatar
Re: C-Clip Rear Ends
I have heard it is very easy, although I have not done it. I have some new ones somewhere... but ya, you should be able to get them at a parts store, otherwise a dealer will have them and they're pretty cheap.
Old Mar 8, 2006 | 11:18 PM
69gto96z's Avatar
Cool, thanks for the info.
Old Mar 9, 2006 | 08:43 AM
94Camaro_Z_28's Avatar
One of the easiest things you'll do. Pull the cover, and theres a pin in there that holds the spider gears and the axles tight. It's held in by an 8mm bolt. Take out the bolt, push the pin out. It's easier on a Posi since the spider gears wont come out. If you're dealing with an open rear and they do, it's no big deal getting them back in.
To replace the clip, with the pin removed, push the rim towards the center of the car, the axle will slide in about a half inch and the c-clip will either fall off or just be sitting there. Pull the old one, slide the new one on. Repeat for other side, re-install pin. Gasket, cover, lube.....you're done
Old Mar 9, 2006 | 10:09 AM
wrd1972's Avatar
Very easy to do. Easily less than an hour.
Old Mar 10, 2006 | 02:27 PM
69gto96z's Avatar
So on my stock 3.42 rear end the spider gears wont fall out will they?
Old Mar 10, 2006 | 02:52 PM
wrd1972's Avatar
No, they are captured in there plenty tight by the springs.
Old Mar 11, 2006 | 06:46 PM
69gto96z's Avatar
Well it was pretty easy to do. Thanks for all the info.
Old Mar 12, 2006 | 08:16 AM
StudyTime's Avatar
Where did you pick them up at? Glad to know it went well.
Ben T.
Old Mar 14, 2006 | 01:04 AM
69gto96z's Avatar
I had to get them at a dealership. It was a dealer only part, and I went to 3 different dealerships before they finally sent me to the right one.
Old Mar 28, 2006 | 12:46 AM
69gto96z's Avatar
Well this did not fix my problem. Both axles still have about an 1/8" of play in em. What else could cause this?
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
