Trans rebuild
Re: Trans rebuild
Ken Walls in Orlando if you want to have it done, Mad Dog Lou if you want to do removal/install. www.maddog-transmissions.com That is what is in my GTA, and would definately use again!!!
Re: Trans rebuild
Oh, if it is a 700r4, for sure mad dog. $1495 and it will handle 750hp supposedly. I don't have anywhere near that, but is will rip the tires into 2nd. Nice tranny. Cheap rebuilds start at $495 plus core, delivery, and convertor. $1495 included 2000 stall convertor, cooler, and shipping. Check it out!
Re: Trans rebuild
The trans you mentioned sounds like a ford tranny.The 1993's have 700R4's from the factory 3 speed with an overdrive = 4 , detent cable shifted.......... Same thing as a 4l60E just not elec. shifted
Have a camera?
Have a camera?
Re: Trans rebuild
Yeah just look for the cable on the passenger side of the tranny just behind the servo cover. Whereabouts in FL are you located? Im in Broward Co. and I can do a benchjob rebuild or full service. Pm me on needs and goals and Ill get back at ya.
Re: Trans rebuild
the 4l60 and 700 are the same as far as internals i have been building them for a little bit i would say i am still a beginner thouigh but if you wanted to bring it to me i could do a bench job for around a grand
here is what i do to the 700s and 4l60e
13 vane front pump
the beast sunshell
3/4 hd clutchpack kit 9 clutched instead of 6 in the 3-4 pack
superior shift kit
i beef up the center support with an aftermarket kit
corvette servo
and a few plugs here and there
if you are interested post
the parts alone will be about 340 with a a or b stall converter unless you want to go higher
13 vane front pump
the beast sunshell
superior shift kit
corvette servo
carguyshu
Jan 22, 2017 11:19 AM
Sergio
Jan 27, 2016 04:27 PM
Nostang 96z
Sep 14, 2002 08:22 PM
