required parts to finish obd1 conv.
Old Nov 3, 2002 | 06:34 PM
SC383's Avatar
Smile required parts to finish obd1 conv.
I have ordered the obd1 pcm, now what else will I need to finish the conversion to start my own tuning. If you guys can give me a list and approximate prices.
thanks, nate
Old Nov 3, 2002 | 09:16 PM
Dave 96TA's Avatar
After the PCM all you need is the '95 knock sensor. This threads into the block right above the starter. Just drain the radiator, then pull the coolant drain plug opposite the knock sensor (on the driver side--theres a lot in there!), last unscrew the old knock sensor and thread in the new one. No need to use thread sealer, as the AC/Delco part comes with it. Refill the coolant, bleed the system, and start tuning.
Visit rockauto.com and look up the knock sensor for a '95 Z28 - that'll give you the part # to ask for at the parts counter (they had to order mine, so give them a couple days notice) or you can order right from the website.
Noer
Feb 28, 2015 11:29 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Wilson
Jul 21, 2002 05:08 PM
