Quick spark plug question
Old Feb 7, 2006 | 07:53 PM
BMAN'S SCZ's Avatar
I used NGK TR6's in my stock 8# setup with no problems. But now I am going to run 10-12# on my 383 with AFR's. Should I stick with the NGK's or go with Auotlite's. I did a search and it seems to be 50/50. Also the 104's are comparable to TR6's or is it the 103's. What would/are you guys running on similiar setups. Thanks....John
Old Feb 8, 2006 | 04:58 PM
OBE1 95Z28's Avatar
Re: Quick spark plug question
TR6 is one heat range colder than stock (so is the Autolite 104). Autolite 103 is 2 heat ranges colder and will probably be needed to 10 - 12# of boost.
Old Feb 9, 2006 | 02:29 PM
Flip94ta's Avatar
I have been running 104's with 14lbs for a while without problems.
mritter1965
Feb 9, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
