Tsp 224r
Old Feb 7, 2006 | 01:09 AM
Black9TA8's Avatar
Tsp 224r
Is this cam 224R(XE-R lobes) worth the beating the springs will take to gain a few more hp under the curve vs. a TR or TSP 224 with XE lobes?
Old Feb 7, 2006 | 05:33 AM
teke184's Avatar
Re: Tsp 224r
how much do you drive the car?
the springs would probably still last 30k miles. for me that would be over 4 yrs probably.
so $200 in springs every 4 yrs...not horrible for an extra 10-15hp (guess)
Old Feb 7, 2006 | 11:53 AM
Greed4Speed's Avatar
Re: Tsp 224r
Its what a .022" difference? Just get the patriot gold spring kit instead of the 918's and don't worry about it.
Old Feb 8, 2006 | 01:16 AM
Black9TA8's Avatar
Re: Tsp 224r
Yeah, I just bought the Patriot LS6 style heads and they come with the gold dual springs. I just don't want to have to change the springs every 10-15k. 30k I could live with. Does anyone know the difference in spring life between the XE and XER 224 lobes?
Old Feb 8, 2006 | 09:47 AM
Re: Tsp 224r
It varies with how you drive etc. With ANY aftermarket cam you should check your springs at regular intervals.
W/those patriot heads you should get the patriot 226/226 cam if its cheaper.
Old Feb 8, 2006 | 01:05 PM
Black9TA8's Avatar
Re: Tsp 224r
I would, but I live in CA and need a smog legal cam.
Old Feb 8, 2006 | 02:46 PM
Re: Tsp 224r
The 224 has been known to pass, but still may not. It is boarder line.
Personally, I don't see why more CA people don't run the CheaTR. It's designed to work better with the restrictions you'll face.
Old Feb 9, 2006 | 04:10 AM
Black9TA8's Avatar
Re: Tsp 224r
From what I've seen here in CA, the 224's on a 114 pass easily. This is a very popular cam here. Now the 224/228 on a 114 is definately borderline, but most even pass with this cam on a good tune. Sometimes I wish I lived where you do, so I could run what I really want to. I just solved my problem today though.......and ordered a custom cam.
Old Feb 9, 2006 | 09:33 AM
Re: Tsp 224r
Cool, what specs and who's grind?
Old Feb 9, 2006 | 10:14 AM
GPZ28's Avatar
Re: Tsp 224r
Ive got a 222/224 581 on a 114+4 ready to go in, I live in socal and hope I pass. Got the car smogged yesterday so I have 2 years before I have to worry about it.
Old Feb 10, 2006 | 01:26 AM
Black9TA8's Avatar
Re: Tsp 224r
It's a 93pony custom. It's a 224/224 .58x"/.56x" on a 114 LSA with no advance. It'll make more peak and "under the curve" power than the OTS cams. I'm just bumbed I have to wait a couple weeks to get it.
Old Feb 10, 2006 | 12:00 PM
00cls1camaross's Avatar
Re: Tsp 224r
that sounds like a good combination, your going to have to get a dyno chart up on here so i can see what it looks like, i wanted to run something similar to that
Old Feb 10, 2006 | 11:07 PM
Black9TA8's Avatar
Re: Tsp 224r
I tune my car with hp tuners "on the fly", so I've never dyno'd. I'll probably do the same after the swap. I could stop by force fed and have it dyno'd....I am pretty curious. I'll try and dyno it and post up. There's a guy here that dyno'd a 93pony cam, with midlengths and stock heads at 400/395. I'm thinking I should make some nice #'s with the addition of stage II heads 10.75:1 compression and longtubes.
Old Feb 10, 2006 | 11:09 PM
Black9TA8's Avatar
Re: Tsp 224r
How is smog in Scottsdale? MY friend just moved there and want's me to move. I heard they are pretty strict like CA also. Do they have the roller dyno sniffer, or just OBDII check?
Old Feb 11, 2006 | 01:21 AM
Re: Tsp 224r
just the obdII scan, they dont do a sniff test or tailpipe emisions... i was just at pro dyno and they said they had 800hp camaros passing emissions with flying colors lol
so they arnt that hard
-Dakota
