what sensor is this?
Old Jan 27, 2006 | 10:07 AM
Terran2k's Avatar
Recently did my back brakes for the 1st time, usually i just let my dad do it at his job since he's a mechanic. Anyway, whats the sensor near the calipers in the rear? had one by each rear caliper.
Thanks
Old Jan 27, 2006 | 10:19 AM
94Z28/SSw's Avatar
Re: what sensor is this?
I believe its for the ABS system
Old Jan 27, 2006 | 11:19 AM
TraceZ's Avatar
Correct. wheel sensors for the ABS System.
A 4 channel ABS system will have 2 sensors in front and 2 in back. F-bodies with the 4 channel system are equipped with TCS. It sounds like your car is a 4 channel car.
Cars without TCS are 3 channel cars. They only have one sensor in the back, up on the top center of the differential. My cars are both like this.
Old Jan 27, 2006 | 01:06 PM
MyShibbyZ28's Avatar
Mine is like this too. It is basically a magnet sensing the rotation of the gears, once the gears stop the ABS kicks in.
Old Jan 27, 2006 | 01:13 PM
flatlander757's Avatar
The tone ring in the wheel speed sensors send an AC current back to the computer to keep check on the varying speeds, and will then makes the brakes pulse if it senses a wheel is slipping.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
