Structural foam. Light and cheap way for Camaro to pass roof crush.
Re: Structural foam. Light and cheap way for Camaro to pass roof crush.
And for side impact -Ultralight steel. Stronger, lighter, no cost penalty.
http://www.ulsab.org/ulsac/index.htm
And Ultra-light steel suspensions. Cost the same as stamped steel, as light as aluminum.
http://www.ulsab.org/ulsas/index.htm
Put 'em all together....it seems we've probably trimmed several hundred pounds off the Camaro at no significant additional cost. It can't be that easy?
Any engineers want to chime in?
Yeah, sounds way too good to be true, therefore it prolly isnt able to be done for some reason or another. Using all of these technologies would allow GM to build a lightweight car that is extremely safe...something that would make it stand out in the auto industry...something GM hasnt done alot of lately.
The foam part of the article is a bit misleading. You wouldnt per say, make a roof out of a special foam to make it stronger. When foam is used in composite materials, its used as a sandwich material.
Say you have a plate of material... may steel, or composite. A thicker piece of material is going to have a higher bending stiffness. It is the material furthest from the neutral axis (think centerline for simplicity) which has the most weighting in material bending stiffness.
Say you have a half inch thick plate of steel which has all the necessary strength properties, but you want to make it stiffer without adding lots of weight. (ie, using a plate of pure steel twice as thick) You can simply take 2 quarter inch plates and sanwich foam inbetween them. The foam is weaker than the steel, so it doesnt add any tensile stength, but now since the steels pieces are further from the central axis, you have a stiffer plate. This is good for a roof beause they bend, not pull apart during a roll over. Sandwiches are used all the time in high stiffness/low density applications.
Converting to that system may require the redisgn of a few componets, new toolign and machinery. Say you save 15% weight on your suspension converting to that system. Is that a cost effective move for a high volume, affordable car like a Camaro?
I'm willing to bet GM is doign everyting in their power to keep weight down and employing all of the cost effective technologies that they have at their disposal.
In regards to these steel links, if the technology is new, you probably wont see it for a few years out.
I think the foam is injected or pumped...as a 'foam'... into a roof structure, like an A pillar, and then hardens.
Other popular sandwhich materials are balsa wood (ie. Z06) and aluminum honey comb. Foam, depending on whats used is going to be one of the cheapest and easiest materials to work with becuase like you said, it can be injected.
Could you explain the part about a matching mass not being the same as a matching weight? Is there some jargon that I am missing because I thought that in a constant gravitational field the phrases are essentially the same thing?
My fault there. When I read the link late last night I mis-interpreted what they were saying. I though they were trying to say they could take a piece designed in aluminum and "cookie cutter" the design using steel.
They're saying they use less total steel in the new design to achieve similar weight savings to designing the exact same part in aluminum.
