buying a nitrous setup..is this all i need?
Old Jan 16, 2006 | 08:11 PM
94_camm's Avatar
bottle/fuel/NOS solinoids/all the braided lines and a nozzle,2 sets of jets would this all i need to hook it up beside a switch? and wat would b a good switch for this..? thanks alot.. also is compucar a good setup?
Old Jan 16, 2006 | 09:38 PM
OBE1 95Z28's Avatar
Re: buying a nitrous setup..is this all i need?
Use the SEARCH function; you'll find that a rpm window switch, bottle warmer, fuel pressure safety switch and blowdown tube are all smart parts to use. Dyno tune with a wideband O2 system to get your air/fuel ratio right (right jet sizes).
Old Jan 16, 2006 | 09:40 PM
AF96Z28's Avatar
You'll also want a purge so you can do it like Fast and the Furious
camaroguy50613
May 27, 2016 09:00 AM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
bandit383lt4
Dec 21, 2014 09:12 PM
