Old 01-14-2006, 12:59 AM   #1
AdioSS
Send a message via AIM to AdioSS
Talking How about this? V8 standard base engine
We all know that the V6 "base" cars are the big sellers. I'm wondering why the base engine even needs to be a V6? GM Powertrain has such a wide V8 arsenal that ranges from the 4.8L LR4 to the big 7.0L LS7. I could definitely see an aluminum block and DOD/AFM & VVT equipped 4.8L V8 as the standard engine. It has the same small bore as the 5.3L with a shorter stroke, so the block used in Trailblazer would work since it already has DOD. It has the ability to get the same fuel economy ratings as Ford's V6 Stang. Look at the 1/2 ton trucks for an example. A 4.8L V8 A4 Silverado is rated at 16/21mpg compared to a 4.2L V6 A4 F150's rating of 16/20. Add DOD/AFM and a 6 speed automatic transmission to the 4.8L and you are sure to get even better economy. While cruising on 4 cylinders it would be getting similar mileage to what a 2.4L Ecotec gets.
Look at the specs of the current LR4. 285hp@5200/295tq@4000 on 87 octane. Compared to the V6 engines in this class, that is dang good.
I consider the Nissan VQ35 to be at the top of the line and it is making 287hp@6200rpm/274lb-ft@4800rpm with the automatic and 300hp@6400rpm/260lb-ft@4800rpm with the manual.
The current Stang base engine makes 210hp@5250/240tq@3500. It is rumored to be getting a lot more than that soon.
The Charger's base engine makes 250hp@6400/250tq@3800.
It has got to be easier for assembly and certification to have all the engines in a model externally identical. I say the same about the transmissions also. The base model can benefit from 6 speed autos and manuals just as much as the higher end models.
The only thing (that I can see) that the V6 has going for it is the reduced weight.
One more thing that is on my mind is the complaining about DOD/AFM. Why not have a switch for it? ON/AUTO/OFF There are times when I would like to drop half my cylinders to pick up a few MPG. When gas prices skyrocket on holiday weekends, after a disaster, etc. just switch over to 4 cylinder mode all the time. Millions of cars get around with 140ish horsepower all the time.
Switch it to AUTO and have it operate as normal. And have it switched OFF for the folks that are paranoid.
And to compliment the DOD, have adjustable mufflers like the Z06. They close off and get really quiet when in 4 cylinder mode. Open it up for V8 mode above a certain RPM. Have the baffles hooked up to the switch also.
__________________
ChestonPhillips@yahoo.com
Quote:
Originally Posted by Bob Cosby View Post
Now we're speculating on the speculation....all the while, throwing more speculation into the mix. Is one speculation (or "most realistic guess") any better than the other speculation?
AdioSS is offline   Reply With Quote
Old 01-14-2006, 01:07 AM   #2
RussStang
Re: How about this? V8 standard base engine
I don't think it is a bad idea, but I think alot of the guys on here are going to scream bloody murder about not having a v6 at all, regardless of the businesss case made for it.
__________________
2000 camaro z28 convertible-black on black
RussStang is offline   Reply With Quote
Old 01-14-2006, 01:18 AM   #3
turbo96z28
turbo96z28's Avatar
2 things are wrong with having a base V8:
1. puplic perception. no matter how good any V8's fuel economy is, there are still plenty of people that wouldn't buy it just because it's a V8. if a parent wants to buy their kid a graduation gift, they'd be more likely to get a Mustang for the simple fact it has a V6 if the Camaro's only engines are all V8s
2. insurance companies. V8s cost more to insure plain and simple.
this has been a hot topic around here for a long time. i can see both sides of it, but i think logically, the V6 has to be there.
__________________
Billy
96 Z/28-not stock
86 Z/28-not stock
96 Ford Ranger-6in lift, 3in body. 37x12.50R15s
88 Jeep Wrangler-6in lift, 2in body, 33x12.20R15s
63 Dodge Town Panel-440, 4spd
Quote:
Originally Posted by 91Z28350
Ain't happening, the SS will have higher HP (stock), you watch and see. If I am wrong, I will get Z/28 put in the empty banner of my tatoo.
turbo96z28 is offline   Reply With Quote
Old 01-14-2006, 03:11 AM   #4
jg95z28
Premium Member
jg95z28's Avatar
Send a message via AIM to jg95z28
Quote:
Actually that's not true. I used to believe that myself, until I checked on the insurance for my 17 year-old stepson. For a 1996 Mustang V6 it was exactly twice the cost of a 1996 Mustang GT V8.
Yeah, that's what I said, "You've got to be kidding me." The insurance company couldn't explain why either, "that's just what it is."
I agree with you on the public perception part though. As long as Ford sells a V6 Mustang, GM will have to sell a V6 Camaro.
__________________
My Current Chevys:
1967 Camaro Coupe - 350HO/TKO-500 (Old Blue)
1967 Camaro RS - 327/PG (Goldie)
1995 Camaro Z28 - LT1/A4 (Norma Jean)
2002 Tahoe LS 2WD - LR4/A4 (The Big Red Truck)
jg95z28 is offline   Reply With Quote
Old 01-14-2006, 03:55 AM   #5
turbo96z28
turbo96z28's Avatar
i guess times have changed.
when i was 17 (9 years ago), it cost more for any V8 F-body then it did for a V6.
i guess the amount of claims plays into it to an extent, and the average age of the owner.
the only thing i could think that would explain a V6 Stang costing more than a GT is more sub-25 kids have V6 cars than V8s.
__________________
Billy
96 Z/28-not stock
86 Z/28-not stock
Old 01-14-2006, 04:03 AM   #6
HAZ-Matt
Send a message via AIM to HAZ-Matt
Insurance rates are calculated by the amount they have to pay out for that demographic in that car.
I agree with the stigma thing. You probably can't have a V8 base car because too many people would be afraid of it.
HAZ-Matt is offline   Reply With Quote
Old 01-14-2006, 09:57 AM   #7
routesixtysixer
I doubt an aluminum-block 4.8 or 5.3 is any heavier than a iron-block 3.9. I know that my 01 Formula curb weight was listed as the same as a V-6 Firebird with the iron-block 3.8. And a LSx is probably no more expensive (possibly cheaper) than the competition's overhead-cam aluminum-block V-6's. I think it makes sense economically and would be a great advantage to market a minimally-equipped V-8 sporty car that gets as good, if not better, mileage than the competition. That said, it'll never happen; perception is everything and the perception is that V-8's get bad mileage and are expensive to buy, own and operate.
__________________
2008 Trailblazer SS AWD ~ 2008 GMC Sierra Ext. Cab SLT ~ 2006 Chevrolet Impala 3LT
routesixtysixer is offline   Reply With Quote
Old 01-14-2006, 10:01 AM   #8
Jason E
A base V8 will never, never, never, ever happen. I thought this was obvious by now...
And for those of you who want a V8 anyway, why do you care if a V6 is base?
__________________
1991 Camaro RS - 1997 30th Anniversary Z28
2004 Appaloosa Mare - 2006 Quarter Horse Mare 1 HP each
2004 Grand Prix GTP Comp G - Hauls the Wife
2005 Ram 2500 Regular Cab SLT Hemi 4x4 - Hauls the Appaloosa
Jason E is offline   Reply With Quote
Old 01-14-2006, 10:16 AM   #9
R377
Insurance and image are definitely the big hitters.
Also, having a base V6 makes it easier to charge a premium for the V8, even if the manufacturing costs are more or less the same (think CTS and CTS-V). If you want a base Camaro to start at $23k and it already has a V8, how many people are going to want to pay $5k just to get a bigger V8? Being able to charge a lot more for things like this that don't actually cost a lot more to produce, plays a big part in making the business case for the car.
__________________
2009 G8 GT
R377 is offline   Reply With Quote
Old 01-14-2006, 10:17 AM   #10
merlinsteele
merlinsteele's Avatar
I've mentioned this before, and I don't think it's a bad idea. I'm not much of a gearhead, so what would be the diff in size and weight between a large V6 and small V8? Look at Ford's 4.6, which is what I have in my F150; maybe GM could do something similar but give it better gas mileage, as I keep hearing that they can do.
As far as perception goes, couldn't GM market it as a 'small' but tough V8? How could this be spun to work? Hmmm...
merlinsteele is offline   Reply With Quote
Old 01-14-2006, 10:42 AM   #11
Honda Hunter
Honda Hunter's Avatar
I like the way you think. Wont happen though.
__________________
~1992 Dodge Stealth R/T TT
Honda Hunter is offline   Reply With Quote
Old 01-14-2006, 11:04 AM   #12
RhinoSS
to insure me on m '02 SS it is VASTLY more expensive than the v6 model. It is the same for my 16 year old brother as well.
I'm sure different insurance companies, and to a lesser extent, the area of the country you live in, have an effect on the insurance rate.
RhinoSS is offline   Reply With Quote
Old 01-14-2006, 11:10 AM   #13
94Camaro_Z_28
94Camaro_Z_28's Avatar
Send a message via ICQ to 94Camaro_Z_28 Send a message via AIM to 94Camaro_Z_28 Send a message via MSN to 94Camaro_Z_28
My Camaro Z28 costs me $28/month full coverage. My V6 Pontiac Sunbird costs me $59/month full coverage. They both have the exact same coverage, the same deductable, the same status(driven daily). I go through State Farm, have been with them since I started driving 6 years ago. No wrecks, not a single ticket...and it shows. I'm 21....so I thought these rates were stupid low...
__________________
1994 Camaro Z28 (Brooke) - Not Stock
1999 Grand Prix GTP (Britney) - Bone stock
2001 Monte Carlo SS (Taylor) - LOL
94Camaro_Z_28 is offline   Reply With Quote
Old 01-14-2006, 02:58 PM   #14
5thGen
I think the reason you say make the V8 base, is because deep down you want to pay less and get the V8.
If they had (very hypothetical) a no-cost option to go from the V6 to the 4.8L V8, you would not care at all. And if it was under 1000 to go from the base to the 5.3L V8, you wouldn't care much either.
Statistically, yes, the V8 will be less to insure. jgZ28, I understand if you got a single quote making it less for the V8 than the V6, but that does not cover all sub-25 dirvers in all v6/v8 cars. It also could have been a mistake. Comes down to someone typing in the wrong info. Then again, with so few sub-25 drivers insured on the V8, the V6 will have many times more accidents, if they go by those numbers, the V8 will drop while the V6 rises.
The V6 is a necesity. If they offer base V8 with 250 hp, they will be laughed at and ridiculed as having to have a V8 to make less power than a six from nissan or toyota. Having a 250 hp smooth 6 though, will be seen as competitive.
the 5.3L in the new Tahoe gets an EPA est. 21 highway. THat is in a 3 ton vehicle that is much less aerodynamic. I have no doubt this same set up applied to the 4.8L block in the camaro would yield great results, however the view of the public, and the insurance companies will mandate that a V6 be base.
5thGen is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
