Does exhaust HAVE to cross?
Old Jan 1, 2006 | 03:52 PM
30thCamaroZ's Avatar
I figured I'd post this in the advanced tech so I'll get the most info on this topic. I'm considering running 2 ft of exhaust off each header and then a bullet and dump. My ? is does the exhaust have to cross or will the car run fine this way? Also how long does it have to be to not cause the car to miss as it's throwing a code for that with the open headers right now.
Old Jan 1, 2006 | 04:05 PM
Mindgame's Avatar
Re: Does exhaust HAVE to cross?
Do you need a cross-over pipe? No, nothing says you have to use one. The engine would be a little quieter with a cross-over and it may make a few more hp/tq but it'll run fine without one. As long as you have ~1 foot of pipe behind the O2 sensor you shouldn't have a problem there.
What code is the PCM showing you, P0300??
-Mindgame
Old Jan 1, 2006 | 04:15 PM
-Mindgame
Yes it's throwing P0300 so I'm assuming it's due to the open headers. Will I lose a lot of torque this way? I'd have thought the hp might be a lil up but the tq would be down. this is more a temporary (cheap) fix for now till I get an x pipe down the road. just want to make sure it'll work
HarleyZ28
Oct 5, 2015 06:23 AM
May 15, 2015 10:43 AM
guionM
9
Aug 29, 2002 01:48 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
