which is the best line lock for our cars
Old Dec 30, 2005 | 06:09 PM
ghost stripes's Avatar
i have a 95 ta and i want to buy a line lock whats the easiest one to put on our cars?
Old Dec 30, 2005 | 07:56 PM
ABA383's Avatar
Re: which is the best line lock for our cars
There's probably one cheaper, but I use the SLP one...Its a complete kit with prebent lines, wiring, and switch...$125 and has worked flawlessly for 2 years...
--Alan
Old Dec 30, 2005 | 08:01 PM
magnumv8's Avatar
another vote for the SLP kit.
Old Dec 31, 2005 | 09:23 AM
where do you get the slp kit...i havent seen it on jegs.com...please send the link to where i can buy it ....thanks
Old Dec 31, 2005 | 09:29 AM
ABA383's Avatar
I don't know what year car you have...here's the link to the 93-97...The LS1 kit is above it...
http://store.summitracing.com/defaul...h.asp&N=400404
--Alan
Crap...I just gave you the all the SLP stuff...just click on brake systems and you'll see them...Or I think you can still get them via SLPonline.com
Old Jan 4, 2006 | 03:22 PM
TQdrivenws6's Avatar
I went with the ABS delete / line lock kit from SJM Manufacturing and I have used it many times so far. The ABS delete was a good 15 pounds out of the front of the car and it didn't really do much anyway with the 9" in the car. I know SJM also sells kits that are compatible with the ABS unit if you wish to retain it.
Old Jan 4, 2006 | 03:50 PM
89385formula's Avatar
That is the same setup i am getting. I am not sure whether to get the Biondo style line lock or the rebuildable hurst setup....which did you opt for?
Old Jan 4, 2006 | 03:56 PM
I just got the Biondo setup. Install tip: flaring the lines in the car is damn near impossible, taking the lines out might seem like alot of work, but even with that you will get done alot faster.
Old Jan 4, 2006 | 04:04 PM
Yeah thats the one I was gonna go with, thanks for your input, and the install tips.
ro2207
Dec 4, 2014 06:18 PM
Dec 4, 2014 11:56 AM
blac94Z
Nov 28, 2014 01:53 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
