new single plain intake design...
Old Dec 15, 2005 | 04:00 PM
LT4POWR's Avatar
http://forums.corvetteforum.com/show...42&forum_id=48
Interesting...seems like it would work good for big cubes & high rpm. What do you guys think?
Old Dec 15, 2005 | 04:18 PM
SStrokerAce's Avatar
Re: new single plain intake design...
Short side on that elbow is a killer.
Bret
Old Dec 15, 2005 | 04:36 PM
MEAN LT1's Avatar
Bret
But could you make it work with out alot of pressure drop?.
Old Dec 15, 2005 | 09:35 PM
Z284thgen's Avatar
best part about that is its built for a TPI head wont do no good on a LT with out other work to make it bolt up.......
might as well just call bret tell him your plans and let him do a conversion for you
Old Dec 15, 2005 | 10:17 PM
atljar's Avatar
LPE/Accel make an elbow just like that ready to go. Ive posted on it before if you search my name plus accel elbow
Old Dec 15, 2005 | 10:40 PM
FASTFATBOY's Avatar
I have seen those Vette boys take a carb intake and bolt a "box" onto the carb mount with bolts that go all the way through, and bolted a throttlebody on the front.....ran 10's on motor if memory serves.
David
Old Dec 15, 2005 | 10:45 PM
mastrdrver's Avatar
thread
Thought I'd help out.
Old Dec 16, 2005 | 12:07 PM
ejfagala's Avatar
David
More then one is in the 10's with Jebs old intake I think the newone wil be even better. The reason for him making the intake and the reason it is short is the fact it was made to be used in a C4 with the stock hood. We have limited clearance and all of the after market intakes other then mini-ram and SR wont clear.
http://forums.corvetteforum.com/member.php?userid=13472
http://forums.corvetteforum.com/member.php?u=22200
http://forums.corvetteforum.com/member.php?userid=50
http://forums.corvetteforum.com/member.php?userid=15516
Old Dec 16, 2005 | 12:47 PM
LT4POWR's Avatar
I'm thinking that it can't be much better/worse than any of the other elbows or elbow type plenums out there.
Old Dec 16, 2005 | 01:58 PM
Honda Hunter's Avatar
How much does the intake and conversion cost? Also when should one need or look into getting one?
Old Dec 16, 2005 | 09:37 PM
ejfagala's Avatar
I compleatly agree unless you have a C4 corvette. The hoods on these cars are big $$$ and most don't want to hack a hole in the hood so that is the real atvantage of Jeb's setup. There are plenty of single plan intakes out there with the elbow that will work on most cars just not the C4.
Old Dec 18, 2005 | 11:24 AM
sseeya's Avatar
Is the reason for an elbow like this just because of hood clearance?
Old Dec 18, 2005 | 10:44 PM
Mindgame's Avatar
Well it could be worse but I'm not exactly sure what the effect would be. My thinking is probably in line with Bret's when he mentions the short side radius. My intuition says it should be as large as possible for a gentle transition into the main plenum but what do I know. Never tested it one way or the other.
sseeya,
Yep, it's all about hood clearance.
-Mindgame
Old Dec 19, 2005 | 05:27 AM
sseeya's Avatar
sseeya,
-Mindgame
I figured it must be, because there are several aftermarket companies that make 1000+ CFM, 4 barrel throttle bodies that bolt right up to a single plane intake manifold. Holley, Accel, and Ron's Fuel Injection are three that come to mind.
Old Dec 19, 2005 | 02:35 PM
Funny I still cant find one of these elbows from Holley, Accel or Rons. I've seen a picture of the Accel one and it seems to have the same problem as this sheet metal one.
Bret
