Intake Porting
Old Dec 3, 2005 | 08:30 AM
GREAT_WHITE's Avatar
Intake Porting
Where Is A Good Place Here In Texas To Get An Intake Ported ?? I Have Heard Of One In Houston ( Cant Remember The Name )... Any Info ?? Web Sites ??
Thanks
Kris
Old Dec 6, 2005 | 12:45 PM
fast 93 z's Avatar
Re: Intake Porting
PORT PROS in Austin
pm sent for info
Old Dec 6, 2005 | 06:15 PM
ulakovic22's Avatar
Re: Intake Porting
Musser Engineering did mine. Search for Jordan Musser and you can get his contact info. He's in College Station. Lloyd Elliot here in Dallas can do it as well.
Old Dec 7, 2005 | 09:30 PM
97 RedSS's Avatar
Re: Intake Porting
Give Lloyd Elliot a ring
972-617-5671
He will do a Grade A job for a very good price..all my porting needs go to him
What intake are you planning on porting?
Cody
Old Dec 12, 2005 | 06:43 PM
Re: Intake Porting
972-617-5671
Cody
LOOKING AT HAVING THE INTAKE PORTED ON THE 77 TA,,,AND WHY DONT YOU CALL ME ??? YOU ARE THE HARDEST PERSON TO GET AHOLD OF......HOLLER AT YA BOY
Old Dec 12, 2005 | 11:16 PM
ulakovic22's Avatar
Re: Intake Porting
A little off base, but is the manifold a stock manifold or an aftermarket one? Does it go on a 400 or 403? Just wondering.
Old Dec 13, 2005 | 01:02 PM
Re: Intake Porting
It Is For A 403.....its To Hard To Find An Intake That You Can Use And Still Keep The Shaker Functional......trying To Keep It Stock Looking I Guess,,,,, Would Rather Have An Aftermarket Inatake,,, Just Cant Find One To Work,,,they Are All To Tall
Old Dec 13, 2005 | 02:37 PM
ulakovic22's Avatar
Re: Intake Porting
Yeah it's not too hard tho. Edelbrock makes the Preformer that will fit, not the 7111, but it's not that much better than stock design wise, just a lot lighter.
http://www.edelbrock.com/automotive/man_olds.html
You have to use a Holley carb with it if you plan on running an EGR tho. No EGR and the clearance for the linkage is fine. Offenhouser makes one too that will work that is a better design. Check out www.mondellotwister.com for ideas on what to use. I wouldn't suggest buying anything from them tho. Their customer service isn't that great and they are expensive, but they do make some good engines. I used to have a 79 T/A so I know what you are going thru. Another route would be to get an Olds 455 and use that. Lots of torque to get that thing moving and a lot more options out there. You can use the same engine mounts and everything too, it'll drop right in no problems.
Old Dec 13, 2005 | 11:28 PM
Re: Intake Porting
well would rather keep it close to original,,,,might put a 454 in it for a while
Old Dec 14, 2005 | 08:41 AM
ulakovic22's Avatar
Re: Intake Porting
Original is good, make sure you do something with the bottom end of that 403 when you are ready to build it up, like a girdle or something. You can make some serious power out of those things, just gotta spin them a little higher. Also you will want to find some #5 casting heads. The 4A's will work, it just takes more work to port them since they are smog heads. They actually flow really well when ported, so if you have the extra cash it can be done. For port work check out Mid Am Performance, they do a great job and are very helpful.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
mightymouse383
May 21, 2015 05:31 PM
LT14LIFE
Feb 9, 2015 09:35 PM
MadMav
Feb 6, 2015 11:02 PM
