Burnouts
Old Oct 28, 2002 | 09:41 PM
joed4640's Avatar
Burnouts
all you with the a4's, what is your method of burnout, i have an ongoing despute with a person who swears that neutral droping does less harm to a car than a brake torque, i dissagree but the burnouts are way better1
Old Oct 29, 2002 | 12:35 AM
Green G0blin's Avatar
neutral dropping is not safe!!!!! that stupid whoever said that...power braking is a lot better than nutral dropping..unless you have money and dont mind replacing your tranny often
Old Oct 29, 2002 | 03:39 AM
MustangEater82's Avatar
neutral dropping is hard on the tranny becasue there is a sudden jolt of power, instead of being gradually brought up like power brakeing, which isn't great for a car but not horrendously bad either.
Old Oct 29, 2002 | 10:45 AM
ibanez6rg's Avatar
Neutral dropping is a no, no
Old Oct 29, 2002 | 10:53 AM
94BlackBowtie's Avatar
Neutral dropping = Broken U-Joints = Call a tow truck.
Brake Torquing = Change rear brake pads every so often...
Old Oct 29, 2002 | 01:11 PM
NeoPaladin's Avatar
Agreed. Neutral drops are FAR worse for the transmission.
Brake Torquing is the generally accepted way of doing a burnout in an automatic transmission car.
Old Oct 29, 2002 | 06:36 PM
oil pan 4's Avatar
Don't do that neutral droping it is bad.
Our little stock 4E60L and TH700R4 can't take that kind of abuse.
The torque breaking isn't that grat for a stock trans eather it causes a lot of slippage in the torqure converter and clutch disks that makes a lot of heat.
You have a 3.8 doing N drops won't break a U-joint or break the sun gear it will slowly go to all to hell on you and you will have to find a nother one and pay for it.
Old Oct 29, 2002 | 07:59 PM
Joshs99BlackBeauty's Avatar
would a line lock work?
Old Oct 30, 2002 | 02:46 AM
oil pan 4's Avatar
Did you say line lock?
There cool as hell but no one uses them any more.
Old Oct 30, 2002 | 11:43 AM
TechCam97's Avatar
Talking
Sure! Go ahead and drop from neutral!.............if you want a new tranny.....My friend Adam did that (drop from N) and he's now on a new tranny. Needless to say that his pops wasn't too happy when Adam tried to explain why his tranny blew at only 30k miles.
Old Oct 31, 2002 | 08:23 AM
94TeALFiReBiRd's Avatar
im the reason not to to a n drop i did a 4 or 5 grand one one time and i broke the 2 piece drivesahft right in halF!!!! $600!!
Old Oct 31, 2002 | 10:28 AM
IBJanky's Avatar
Damn a new driveshaft for $600? You got ripped off...
Old Nov 4, 2002 | 08:30 PM
rollin in a camaro's Avatar
k i know that burnouts are bad on the tranny either way, but what will be the safest way to burnout, i know that not doing it would be, but im a teenager boy, and of course i have to show off. is there anything i could buy to have safe ones??
Old Nov 4, 2002 | 09:06 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
the best way to do a safe burnout in an auto is to have enough power to be able to just plant the gas and roast the tires, or if you had a line lock that would be fine on the car. just plain brake torquing isnt that bad, it will take a while until you need a new set of pads
Old Nov 5, 2002 | 11:39 AM
JC93Z's Avatar
Ummmm......I do, and so does everyone else that wants a good consistent burnout at the track.
Line lock is the way to go, you won't be changing brake pads either. Just don't hold it for too long cause you could damage the solenoid.
