which supercharger for my car
Old Nov 24, 2005 | 04:39 PM
97formulakid's Avatar
I almost have enought money saved to get my ATI procharger in the spring. I did plan on building my motor first then adding the procharger later, but i would rather get the blower now and then rebuild the motor to handle a lot of boost.
I want a kit that I can run on a stock car for a year or two then have something i can upgrage to work with a fully forged 355 and put out about 16-18 pounds of boost.
i was thinking about the D1-SC kit with the twin highflow intercoolers. does that sound like a good kit for what I want???
Old Nov 28, 2005 | 10:02 PM
Re: which supercharger for my car
anyone?
Old Nov 28, 2005 | 10:19 PM
JZ28Max's Avatar
that sounds like a good choice. you could talk to ATI about getting the correct pulley to lower your boost to maybe 6-8 lbs until you get the new motor built. the D1sc should get you your desired boost for later when you go forged.
Old Nov 29, 2005 | 09:15 AM
Backfire4200's Avatar
Definitly a good idea, usually if you build your motor for boost, then you'll only run it with boost. Going the other way and getting the charger first is better for now if you don't plan on a build up.
You'll need to upgrade the fuel system, but it will be good for now running low boost until you decide to turn up the go fast ****
Highlander
Jan 12, 2020 02:13 PM
USAirman93
Nov 24, 2014 03:37 PM
tubby
Oct 13, 2003 09:16 AM
NED4SPD
Sep 16, 2002 10:45 PM
Carson96Z28
Aug 28, 2002 05:23 PM
