Loose Pulley
Old Nov 9, 2005 | 08:46 PM
seawolf06's Avatar
Really Loose Pulley, help
I'm pretty sure it's the AC pulley. I'm looking at shoebox's views right now, but I'm on 56k, so it's kinda slow. It's the one directly under the altenator. It's loose, and shaking and making this horrible screeching noise at idle that goes away when I drive around and the rpms are higher. I thought it was the belt, but I saw the pulley shaking today. Can I just tighten it down? That would be too easy I guess. How about taking off just the pulley and replacing it or the bearings in it? Is it a seperate piece from the compressor? That would probably be too easy as well... I need your ideas and suggestions please. Thanks.
Old Nov 9, 2005 | 09:19 PM
Dave89IROC's Avatar
Re: Really Loose Pulley, help
directly below the ALT? is the pulley grooved or smooth?
Old Nov 9, 2005 | 09:27 PM
seawolf06's Avatar
grooved, it's the one below the smooth pulley. looks like there's a bracket in front of it that's not moving.
Old Nov 9, 2005 | 09:34 PM
seawolf06's Avatar
is it the power steering pulley? anyone know how to fix it?
Old Nov 9, 2005 | 09:47 PM
Dave89IROC's Avatar
umm., the grooved one below the smooth one is A/C compressor, the smooth one is the PS pump
Old Nov 9, 2005 | 10:00 PM
seawolf06's Avatar
ok, is it all one piece or what?
Old Nov 9, 2005 | 10:20 PM
Dave89IROC's Avatar
which one?
Old Nov 9, 2005 | 10:24 PM
seawolf06's Avatar
Re: Loose Pulley
the ac compressor? how can i fix it? can you just replace the clutch and that's it? do you have to bleed the entire system and recharge it too?
Old Nov 9, 2005 | 10:29 PM
Dave89IROC's Avatar
Re: Loose Pulley
you can replace just the clutch/pulley, you can get the parts from the dealer or aftermarket, IIRC, you need a special tool to remove the clutch hub, and snap ring pliers to remove the pulley
Old Nov 9, 2005 | 11:16 PM
seawolf06's Avatar
Re: Loose Pulley
ok, thanks. where's the best and cheapest place to get one? should I only get GM or is aftermarket ok too?
Old Nov 14, 2005 | 06:23 PM
seawolf06's Avatar
Re: Loose Pulley
Does anyone have a write up or directions to replace the clutch/coil? How about part numbers?
AviatorDave
Dec 19, 2016 06:35 PM
Mar 13, 2016 03:37 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
