SFC Bolt On or Weld On
Old Nov 5, 2005 | 04:49 PM
ZULATER454's Avatar
Looking into some Subframe Connectors in the near future for my 00' Z28, probably should have got them about 15 mods ago. I'm pretty sure weld on is the way to go, however want some other opinions. Also which brand out there is the best. Thanks
Old Nov 5, 2005 | 04:59 PM
myslowcamaro's Avatar
Re: SFC Bolt On or Weld On
if you are going to do it yourself, bolt on. otherwise weld on. make sure they disconnect the battery so they dont fry the pcm or any other damage.
Old Nov 6, 2005 | 08:12 AM
danziger's Avatar
I did weld-on SFCs, so I can't comment upon bolt-ons. I should have done SFCs as my first mod. My Z28 feels much more stable and taut with less creaks. You can get a decent set for about $100...
Old Nov 6, 2005 | 12:26 PM
StudyTime's Avatar
Try a search. There's a lot of information available on SFCs.
Good luck.
Ben T.
Old Nov 6, 2005 | 12:29 PM
Eric @ DMS's Avatar
We always recommend weld ons. I've seen issues with bolt ons as well as many other users. We only carry weld ons for good reason. Get a set before it's too late. YOu'll be happy you did.
Old Nov 6, 2005 | 02:42 PM
ZULATER454's Avatar
Thanks, your posts supported my belief that I need weld on SFC's, now which brand should I get, also note that my car is lowered 1 1/2", will clearance be an issue. I'm looking at BMR as my choice right now;
BMR Low Clearance
G2
Hotchkis
Spohn
Is there any noticeable differences between these brands.
Old Nov 6, 2005 | 03:50 PM
SFB767's Avatar
My car isn't lowered, but I have BMR boxed SFCs under my car now and they're great. I probably lost maybe 1/4" (1/2" at the most) of ground clearance with these.
You're advised to use tubular SFCs if your car is lowered because they're hidden behind part of the frame, but I honestly couldn't see a mildly lowered F-Body having any ground clearance issues with the boxed SFCs.
Like the other guys said, weld them in. If you're not doing it yourself, find someone who knows exactly what they're doing. You may have to pay over $100 for the install, but you'll get your money's worth from them when they're installed perfectly.
Old Nov 6, 2005 | 09:52 PM
StudyTime's Avatar
I'll install 20 pair a week around classes for that price! Seriously, bolt them in and then drive to a shop and have them welded to your car. It's not that big of a deal. I really don't see how a competent welder could ever mess the install up, but then again people jack their cars off the ground under body panels too... so who knows.
My take is this, if you're going to own an F-body you should AT LEAST be able to bolt an item such as this on. If you're in the other group of f-body owners who pay for such an install, then just drop your car off at a shop with a blank signed check and they'll take care of everything.
Pick your favorite set. Bolt them on. Drive to a shop and then have them welded in place. Fifty bucks should more than take care of the welding if you don't own your own welder.
Just is this my opinion. No need for anyone to be offended...
Ben T.
Old Nov 7, 2005 | 05:09 PM
Eric @ DMS's Avatar
If you go with tubulars, most out there are virtually the same. It'll come down to quality and price. A major factor to take into consideration is how much ground clearance is sacrificed. Ideally you don't want any. That was one criteria when making ours. Do a little research to make sure the ones you want are priced well and do not sacrifice any clearance.
Old Nov 7, 2005 | 05:27 PM
formula79's Avatar
I would do Bolt-On's and weld them in. It is more expensive, but fitment is much easier.
Old Nov 8, 2005 | 10:08 AM
SantaCruz163's Avatar
Weld in SFCs is the only way to go. Bolt holes can get bigger over time, not saying it will, but it can. Welding them in is permenit as long as it was done correctly. They are also cheaper, but labor will cost you more.
Old Nov 8, 2005 | 03:17 PM
Bayer-Z28's Avatar
http://web.camaross.com/forums/showt...t=bolt+SFC%27s
Read what Injuneer wrote. I was thinking about getting bolt-ons, just because it'd be easier. Just remember, bolts can loosten.....
Old Nov 8, 2005 | 10:14 PM
NOSCaMaRo's Avatar
Look into UMI Performance, they offer awesome bolt and weld in SFC's...some of the best bolt ons on the market IMO
HarleyZ28
Oct 5, 2015 06:23 AM
maybe2fast
Mar 16, 2015 09:45 AM
rje
Sep 9, 2002 12:35 PM
