Squeek coming from wheels during turning
Old Nov 2, 2005 | 04:48 PM
Z28LT1_Just_Nasty's Avatar
Any guess as to what causes it? Just the front wheels, as far as I can tell the passenger side, also only when turning to the left. I was planning on getting new ***** joints soon anyway but do you think thats the cause?
Old Nov 4, 2005 | 08:27 PM
OBE1 95Z28's Avatar
Re: Squeek coming from wheels during turning
Crwl under the car and wiggle things around to see if you can isolate the source. Bushings are a common source of squeaks. From my experience worn ball joints don't squeak, then create more of a cluck from play.
Old Nov 6, 2005 | 06:13 PM
methd10's Avatar
my car just started to do the same thing, i thought it sounded like a sqweak (spelling?) too. i took my front tire off today...my brakes need to be done (i had figured it was them, since it had been a while since i changed them. if it aint too much trouble take off the front wheel and check the brakes. the metal indicator may be scratching the rotor. i am not too sure it that is the cause of the sqweaking of my car, but im gonna change the brakes anyway (once i figure how to take off the caliber). i will let you know if that fixed it for me...tuesday. good luck. oh yeah...also, does it do it while the tire is wet? i washed my car the other day, and it stopped sqweaking for a while, then started again (probably when it got dry).
later.
Old Nov 6, 2005 | 10:36 PM
methd10's Avatar
hey -
i changed my front brake pads, and the sqweaking noise stopped -- hopefully that is all you need to do. good luck. (if you change them, you need a 3/8" allen wrench to do it.)
Old Nov 7, 2005 | 04:54 PM
Originally Posted by methd10
hey -
Yea today the squeeking moved to not just during turns but during typical driving. Gets worse when I apply the brakes. Tomorrow I plan on doing the brakes, but thanks for helping me get going in the right direction.
squarehead
Jan 15, 2015 07:02 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
jj71787
Dec 30, 2014 02:15 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
CaRParts102
Dec 6, 2014 08:45 AM
