ABS not working??
Old Oct 29, 2005 | 09:11 PM
matLT1's Avatar
Question ABS not working??
The problem I am having is that in wet weather if I get on the brakes (medium pressure or more) all four tires will lock up and I will go for a fun slide til I let off the brakes. At times on dry pavement they will lock up too. I still have plenty of tread left on the tires so that shouldn't be the cause. And they are Aquaflow tires, so in theory they should be descent for wet pavement!! Do you guys have the same issue with your cars or could this be an ABS issue? Thanks
Old Oct 31, 2005 | 09:45 AM
93transam1234's Avatar
Re: ABS not working??
It sounds like your abs is not working, Is the ABS INOP light on on your dash?
Old Oct 31, 2005 | 10:36 PM
matLT1's Avatar
No, the light isn't on. Someone was telling me I should check the abs fuse out. I think I'll try that.
Old Nov 6, 2005 | 06:20 PM
jakesnake123957's Avatar
MY 94 does that too and its the ABS ,I was almost killed a week ago,better fix it man!
Old Nov 17, 2005 | 09:33 AM
69gto96z's Avatar
Mine does the exact same thing. I wanna figure out what is up. I have almost been killed from it also, in the rain one time. But only my front's lock up. And I dont have an ABS light on.
Old Nov 17, 2005 | 03:50 PM
Yeah man my rt front locks up all the time in the rain,I am pretty sure its my accumulator.>Jake
Old Nov 17, 2005 | 09:26 PM
69gto96z's Avatar
Whats an accumulator? Somebody told me I might have a bad jumper, but that seems like it would cause the ASB INOP light to come in, atleast I think it would.
Old Nov 20, 2005 | 09:09 PM
That is the part on left side of car and with all the brake lines going to it.
Old Nov 21, 2005 | 10:07 PM
OBE1 95Z28's Avatar
All the brake lines go to the ABS module as you can see in the attached photo courtesy of Shoebox
http://shbox.com/1/abs_wiring.jpg
squarehead
Jan 15, 2015 07:02 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
ddr698
Jan 9, 2015 10:05 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
